Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
I have a B & D electric lawnower model LM110 that stopped working when it rolled over a rock. Is there a fuse that can be changed, or a reset button on this model? Thanks
  • xj750xrider Jul 01, 2008
    I have a similar problem with a LM115 mower. My magnet was broken in one spot and the blade would not turn. I disassembled the whole electric motor and vacuumed all the little magnet pieces. The blade is spinning now, but I can't remember how the wires were connected to the rectifier. A diagram or picture would help.
  • Anonymous Jul 03, 2008
    Me too.
    Champion:
  • 313 Answers
Unplug the mower. checked the blade & try to spin by hand the blade. if it not spinning then the magnetic ring is probably broken. if ok open the top housing that held by two screw.inspect if the armature are ok still/not broken.
there is no fuse in the unit. it uses rectifier from ac to 120 dc volts.
Posted on Jun 25, 2008
Can't roll done rear electric windows
If both windows stopped working at the same time then you should check your fuse box to make sure you don't have a blown fuse.
Jan 04, 2013 | 1989 Oldsmobile Eighty Eight Royale
My drivers side window will not roll up. Is there a seperate fuse for it on a 2003 lincoln town car?
the fuse is the same for all,if you can check the contacts on the switch for that window/also the connector that plugs into the switch itself,they can be corroded,oxidation electricity can not pass through,for the switch itself you will see little tabs that lock the switch inside its own housing pop the switch out and get inside the same way the buttons have two brass contacts(1up)(10down)you will see tiny contact buttons clean where they touch each other & put a die electric lube or spray with pb blaster liquid wrench lube once cleaned & lubed it should work,for the connector do the same to clean it,an emory board nail shaper that woman use will also work for both with some trimming,now for the motor itself?did it start to go up slower & then eventually quit if so unplug it clean those contacts for the plug if after all things are done & still no window function the window motor burned out(slower than others and then it quit)if it's the motor you will see three brass torx screws take those out & you will feel a wheel with a cable wrapped around it,hold that wheel & cable tightly & pull on the motor to seperate them,put it back the same way,the window goes up & down by the wheel & cable,so thats the shabang for you in the easiest order electrical contacts first motor second have fun
Dec 29, 2012 | 2003 Lincoln Town Car
Inherited with my new house a lawn mower in good condition black and decker lm110 not sure how to work it / how to plug it in no manual with it
if its electric its pretty simple, a normal standard extension cord will plug right into the socket on the machine,, the only thing left would be the switch,, depending on the year and model,, it could be along the handle rail, or actually part of the handle itself, Just pull on it to make the motor start, if it doesn't start, you can check the switch to see if you have power going to it and when activated passes through to the motor, if that doesn't work,, thats probably why they left it,, the replacement motor would cost as much as a new unit
Sep 17, 2011 | Garden
I have a kenwood amp. The fan is running but no power is running my subs. I have changed all fuses and checked all connections but it still will not turn on how do i solve thus problem?
Check your subs. Make sure they are not toast. Sounds like the amp is on, but it seems like its not working, when it could be your subs burned up. Push on them, and if they don't move and are rock hard you cooked your subs.
Other things it could be.
  • Bad RCA cables.
  • Incorrectly wired subs.
  • Amp in protection mode(must disconnect power to amp for a minute to reset)
Aug 08, 2011 | Kenwood Car Audio & Video
I have a Merlin 230T garage door opener which abruptly stopped working altogether. Could it be the fuse?--or any other suggestions.
There is a fuse in a Model M-230T and I have seen a service man change it.Now that the fuse has blown again, I want to change it myself BUT can't now find it!
Can anyone please offer a guide to changing the fuse?
Sep 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
To fix a electrical fuse for a 1975 roll
Easier to replace with a resetable breaker. Safer too. They are readily available from local electronics store. If you are trying to keep it original looking disconnect the wiring and install a self resetting type, more expensive than normal breaker, and hide the wiring to it.
Nov 22, 2009 | Welding Tools
Electrical system issues
I believe what happened is the battery died and the computer lost its memory, you didn't hook the jumper cables up backwards at all did you even for a minute?
Does it run now do you have a battery meter what does it read?
Aug 15, 2008 | 2007 Kia Rio 5 Sx M/T Hatchback
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
159 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
