Question about Dell Latitude D600 Notebook
Dell latitude D600 problem
When i attempt to turn the computer on,the three lights to the left of the power button flash once and then the center one flashes nine times and the computer shuts off.On the rare occasion it did start,it comes up to a message that states it was shut down abnormally and offers to start it in the last known good mode,but when i try it,the computer freezes.The majority of the time it won`t get that far.
  • 1 more comment
  • John 40 Jun 25, 2008
    i tried both of your suggestions and i got it working again.i am wondering if there could have been a connection that was not 100%.Anyways,it`s working again and my daughter is happy.Thanks guys for your help.I greatly appreciate it.
    John
    Thanks again for your solutions.i tried both suggestions and it is working.Not sure what is was,but i unhooked everything and tried the suggestions and didn`t get any codes,so i put it all back together and it works.Thanks again for the help.
    John
  • Anonymous Mar 30, 2009
    The same , it rarely starts and if only for about 30 seconds an than it goes dead. With or whitout the battery in place. It does'n charche the battery and a new power adoptor did'nt solve the problem
  • 3,940 Answers
The flashing caps lock is an indication of a failed POWER on Self-Test (POST)
Remove the HDD, Battery, AC adapter, RAM and Modem
Press and hold power button for 15 seconds
Connect AC, see if you get any beep codes. If you do, power off, disconnect power, insert RAM, connect AC and reboot. If system boots, power off and add hard drive. If it doesn't, replace the motherboard.
If the system boots with RAM, but fails to boot with HDD, replace HDD 1st.
Posted on Jun 25, 2008
When the caps lock button flashes by itself from 7-15 times:
This indicates a memory problem. Open the small panel on the bottom of the notebook and swap the memory in it's slots.
Posted on Aug 28, 2008
    Genius:
  • 2,028 Answers
Here's a link for Dell's diagnostic codes. You may need to contact Dell directly for this, however, in most cases I've dealt with, this is usually a memory or battery problem. Try starting without the battery, then without one or the other memory chip. Dell machines require at least one memory chip in order to run. It is possible that this is a hard drive issue, it's rare, but possible.
http://pompone.cs.ucsb.edu/admin/530_Workstation/2codes.htm#1170334
Gracias
Posted on Nov 26, 2008
I have a dell latitude d600 when i press the power button with the battery in(just the battery) nothing happens. when i plug the adapter in with/without the battery power comes on and the hd light flashes...
Can you hear the fans starting up.....if you can plug your laptop into a external monitor and see if you can see it boot up...it sound as if you may have a short on the battery pack...
Apr 02, 2011 | Dell Latitude D600 Notebook
plz repair or reload the operating system
Jun 30, 2008 | Dell Latitude D600 Notebook
Latitude D600 PC Notebook: dell d600 three light on and of problam...
This is do to the jack were the power button board plugs into the motherboard, i see this alot on d600 and d610, the lights come on for about 3 sec then computer turns off..
this can be fixed by resoldering the plug to the motherboard but most will say you need a new mother board the leads are small and tight together..
Used motherboard on ebay $60-150
May 17, 2010 | Dell Latitude D600 Notebook
Hi i am using dell latitude d600 problem with charging the battery 3 or 4 time orange light flash n 1 time green light . im unable to use my laptop with battery it working well with A.C power
Try to perform power drain. Take out the battery unplug the power adapter then press and hold the power button for 30secs. Put the battery back in then plugin in the power adapter then turn on the computer. If same issue occur, then you need to replace your battery.
May 18, 2010 | Dell Latitude D600 Notebook
Pushing on power button three green lights come on for one secone
click here you would find the details for led codes. you may select any laptop. codes remain the same.
Sep 24, 2009 | Dell Latitude D600 Notebook
Dell Latitude d600 series.The shut down after start-up
when your computer is freezes up then you download registry mechani it can improve your performance
Jun 28, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 booting problem
Are all three lights on when you hit the power button?
Aug 25, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600
remove the battery and adapter..keep the power button pressed for 10-15 seconds....again plug in the battery\adapter and turn it on...
Feb 08, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
3,088 people viewed this question
Alun Cox
