How to dump toner overflow tank on ricoh ft4421 part number AO487551
I need to know how to dump the toner overflow tank on a ricoh ft4421 it has the part number AO48-7551
  • 1,326 Answers
Is it asking for the waste toner to be emptied???
Posted on Jun 26, 2008
How to reset replacement required print cartridge ricoh sp 3510/3500
"Replace Print Cartridge" remains in
display. Then a new AIO cartridge must
be installed. This feature is a safety
measure to prevent the used toner tank
from becoming full (there is no toner
overflow detection mechanism).
Dec 05, 2015 | Ricoh Aficio Sp 3510sf All-In-One Laser...
RICOH MP 3350B ask for toner even having a new one
Take out the toner cartridge and shake it vigorously. When they sit for a long time the powder tends to clump.
Nov 19, 2014 | Ricoh Office Equipment & Supplies
Error code E70 on ricoh FT 4418
Empty the waste toner tank.
1. Open the front cover
2. Lower the transport unit
3. Pinch the cleaning blade release lever and slide the cleaning unit out.
4. Remove the 4 screws in the top cover of the unit.
5. Dump out the waste toner.
Mar 14, 2011 | Ricoh FT5832 Copier
I need to know the part number for the toner replacement bottle for the Ricoh Aficio 2045 PCL 6
Ricoh Aficio 2045 copier/printers take the Ricoh Type 3110D Toner Cartridge. Go with OEM toner on these machines. The generic version tends to make them run dirty.
Sep 09, 2010 | Office Equipment & Supplies
How to replace waste toner bottle for Ricoh Aficio w3600
1. Lift the original feed unit.
2. Lift the upper unit.
3. Right upper cover
4. Right cover [
5. Loosen the leaf spring and lift it.
6. Toner overflow sensor
7. Toner collection bottle
Once you have it out jsut dump it out (carefully) remove the sensor on the bottle and wipe clean reinstall the sensor re install the bottle and you should be good to go
Jan 21, 2010 | Ricoh CL3000E Laser Printer
I need to empty or repalce the used toner bottle
Hello sir; You may open side door, you will find out a retangle plastic box that is the waste toner bottle, on the top of waste toner bottle have a green knob, just slide it to right, you can remved it and dump it out.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Probems with a waste ink tank on a Ricoh Africio MO C1500 sp
on the right hand side of the machine , open the door you will see a transfer belt unit pull it out,there have a plastic pan remove it dump the waste toner.
Dec 02, 2008 | Ricoh Aficio MP1600SPF Copier
Ricoh ft3713 toner overflow
remove the toner bottle, open the back cover and look for the small DIP Switch turn on and off, by doing this you are forcing the machine to come out from add toner condition. Then you do 20 sky shoot.
Oct 24, 2008 | Ricoh FT3713 Copier
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
152 people viewed this question
jasbo
jasbo
