Power Adapter for Bytecc 3.5" EXTERNAL SUB-SYSTEM
I Need to purchase two(2) Switching Adapters(power input) Model:PA-215. for The External Drive case.
I have 1with a S/N W0407170732
Please send email reply to:
Thank you in advance.
Clifford Chason
8 Roy Ace Street, P.O.BOX 44
Delaware, NJ 07833
Work - 908-704-6805
Home - 908-475-4016
  • brbrjust Sep 05, 2008
    I need 4 pin/ 80 watt, 6.7 amp out put switching adapters
These are readily available on the net. Do a Google search for:
pa-215 "switching adapter". (Enclose the words in quotes, as shown.) Also, check eBay, which probably has them at good prices.
Posted on Jul 13, 2008
Input voltage?
looks like it is 12 V, 1 to 2 amp.
her are some power Adapters listed on amazon. Also, look on the bottom to see what polarity it is (also by mosue over the picture of the adapter in the bottom link (to zoom in)
Amazon com Pwr Extra Long 6 5Ft Cord AC Adapter Charger for Seagate Hdd...
Amazon com Super Power Supply AC DC Adapter Charger Switching Cord Plug...
Apr 28, 2016 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to open case for BYTECC Slim Mobile Drive 2.5" SATA 6G USB 3.0 External Hard Drive
you obviously want to scrap it for magnet or aluminum, so bashit with hammer and split with chisel, etc.
Jan 15, 2013 | BYTECC 2.5" USB 2.0 Slim Hard Drive...
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Installation of BT-146
Yes, you need to plug in a 4 pin FLoppy Molex connector. Your power supply should have at least one. The power connector is right next to the Floppy Drive connector.
Also, the Floppy connector goes in with pin 1 (The red stripe) to the left looking at the unit from the back (furthest away from power).
There is no manual to speak of.
Jan 09, 2009 | BYTECC (BT144) External Floppy Drive
SimpleTech 320GB external hard drive power adapter
I have the same drive and it uses an Accurian AC/DC Adapter. It's output is 6.3V. Also the model number is XKD-C1500NHS66.3-12. I hope this helps.
Nov 09, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Software for 500GB
I don't think BYTECC sells complete external hard drives. But they do sell the enclosures. People buy the enclosures and install a hard drive in them and, now you have a working external hard drive. I have don't this before, but I have never used BYTECC before. You can download the drivers for there enclosures at there website:
They have several different versions, Just pick the correct one, hopefully the enclosure has some markings or a sticker identifying the model.
Nov 17, 2007 | BYTECC 1 Bay ME-350U2 USB 2.0 External...
Problem with external enclosure ( No power)
Perhaps the gentleman at the store did not connect the power from the case to the drive itself.
Feb 11, 2007 | BYTECC 3.5" Aluminum USB 2.0 and Firewire...
Power supply
bshanker, Is it an External Power Supply? Is the power supply part of the power cord? I have a few different models and some have built in powersupplies, some have external. Good Luck, Tim
Feb 07, 2007 | Orange Micro 1 Bay (70HDC00001) ATA-133,...
Computers & Internet Logo
1,337 people viewed this question
David Payne
David Payne
