Question about Garmin GPSMAP 60CS GPS Receiver
GPSMAP 60CSx On the map page I selected Stop Navigation & have not been able to turn it back on. The menu item for stop navigation is greyed out & I cant highlight it to turn it back on. Any sugestions
  • Garmin Master
  • 638 Answers
You can't turn the navigation back on with this method. You must once again highlight the waypoint you want to navigate to in your Fine>Waypoints screen and then press the "Go to" highlighted button on the screen.
Posted on Oct 16, 2008
Keeps beeping and displaying approaching turn
The "Approaching Turn" message is coming from an active navigation on your device. To turn it off, press and hold on the left side of the bezel (GPS), then press the lap/reset/quit key to exit the compass screen. You should then be in the GPS menu. There should be an item in this menu titled "Stop XXXX" where XXXX is "Navigating", or "Back to Start", or something like that. Select that option, and it should stop the navigation, and eliminate the "Approaching Turn" messages.
Sep 29, 2013 | Garmin Forerunner 405 Handheld GPS...
Hp t1100 error 50.2
  1. Remove the printer from any UPS supplies, additional power supplies, or power strips.
  2. Plug the printer into a wall outlet to check whether this resolves the problem.
  3. If the printer is already plugged in, try another power source in the building independent of the one being used.
  4. The line voltage and current source at the printer location might need to be inspected to make sure that it meets the printer's electrical specifications.
  5. Turn the printer off then on.WARNING: Be careful when removing or reseating the fuser. Temperatures can reach 400+ degrees Fahrenheit.
  6. If the message persists, turn the printer off for 30 minutes to allow it to cool, then reseat the fuser after checking the internal wiring connections on the right and left side, ensuring that these connections are properly seated.
  7. If the 50.1 or 50.2 error recurs after power-cycling the printer or when trying to print, try installing a known good fuser from another HP LaserJet 4100 series printer, if available.
  8. If the fuser is near or at the end of its estimated life expectancy (approximately 200,000 pages), then replace the fuser. After replacing the fuser, print a Configuration page, a Menu map (shows fuser settings), an Event log, a Supplies status page, and a Usage page, to reference the status of the new fuser and to ensure that the previous fuser settings are in place with the replacement fuser. To print an Information page on the HP LaserJet 4100, perform the following steps
    1. Press the MENU rocker key until INFORMATION MENU appears on the printer display.
    2. Press the ITEM rocker key until PRINT CONFIGURATION (or until PRINT MENU MAP, etc, appears in the printer display.
    3. Press the SELECT button to print the selected information page.
    To print an information page on the HP LaserJet 4100MFP, perform the following steps
    1. Press the MENU button.
    2. Press the DOWN Navigation button until INFORMATION is highlighted.
    3. Press the RIGHT Navigation button.
    4. Press the DOWN Navigation button to highlight PRINT CONFIGURATION (or PRINT MENU MAP, etc, appears in the printer display.
    5. Press the SELECT button, the button with the checkmark on it to print the selected Information page.
  9. If 50.x errors persist after properly installing a known good fuser, or if the errors follow the questionable fuser (provided it is not near the end of its estimated life expectancy), contact HP for further assistance.
Removing and replacing the fuser
Mar 23, 2013 | HP Designjet T1100 Photo Printer
60CSx switches automatically off directly after connect
Go to Main Menu by pressing MENU button twice. Choose SYSTEM and press ENTER. You can change various settings on this page. Make sure that for GPS option 'Normal' is selected. If it is set to 'Battery Saver Mode' the GPS will switch off after certain time.
Jul 07, 2009 | Garmin GPSMAP 60CSx GPS Receiver
I bought this gpsmap 60CSx unit two weeks ago and wont locate any sats should I upgrate the software how do I know wich version its in it?
To find software version press menu then select setup press enter select system press enter then press menu select software version press enter version 3.90 gave me problems so i downgraded back to v 3.70
Jun 12, 2009 | Garmin GPSMAP 60CSx GPS Receiver
I have cganged settings on my GPSmap 60CS and it now display only waypoints and not complete tracks. Can anybody out there advise?
On the Map page press Menu. From the options shown choose Setup Map. Go to Track tab and make sure Saved Traks is not set to OFF.
Jan 12, 2009 | Garmin GPSMAP 60CSx GPS Receiver
View maps on Garmin Vista HCx
on my 60csx i go to main menu/setup/maps and select the items I want to display.
may be similar on the vista
Oct 21, 2017 | Garmin eTrex Vista GPS Receiver
Fax machine
It is more likely that there is a setting or error... are you receiving any error msges or alerts when you try to fax out?
Just in case here are the steps to turn off fax memory
  1. Follow these directions to turn off the fax memory.
  2. Press Menu/Set.
  3. Press the up or down navigation key until Fax appears and press Menu/Set.
  4. Press the up or down navigation key until Remote Fax Opt appears and press Menu/Set.
  5. Press the up or down navigation key until Fwd/Page/Store or Forward/Store appears and press Menu/Set.
  6. Use the up or down navigation key to select Fax Storage (or Off if you wish to disable Fax Storage). Press Menu/Set to confirm your choice.
  7. Press Stop/Exit to exit the menu.
May 06, 2008 | Brother IntelliFax-2820 Laser Fax
How to Transfer Maps to GPSmap 60csx
Have you highlighted the section with the map select tool, then hit the Transfer to GPS button? If you do, what happens then? Does it freeze?
If you are able to send routes and waypoints to the unit, you should be able to send selected unlocked maps as well.
Dec 31, 2007 | Garmin GPSMAP 60CSx GPS Receiver
How do I get my Garmin GPSMap 60Csx to work with C-map software
Try posting the problem listing your virtual port software or the laptop itself as the product, you may get many more experts taking a look. Other than that, one thing to try would be to set it up on a machine with a serial port, and if you can get it working see what all the settings are - it may give you some clues. I used to use C-map years ago, so probably now much different, but we often had unrecognised port problems that usually meant two or three restarts before it would pick up the port (this was without changing any settings). Maybe they cured this in the last few years, but the best answer I got back then for why it happened was bad software code in c-map, never bothered to try the later versions. Hope this helps a bit :)
Jan 16, 2007 | Garmin GPSMAP 60CSx
Garmin GPSMAP 60CS GPS Receiver Logo
97 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
