Question about Minolta Maxxum 7000 35mm SLR Camera
Rewinding on a minolta 7000
How do you rewind the film on a minolta 7000 maxxium
    Genius:
  • 1,689 Answers
I used to do this on an old Kyocera, and somehow looking at the 7000 diagram, they have the same, almost the same design.
take the camera to somewhere dark and clean (like dust free and all) perhaps your darkroom if you have one, bring a pair os scissor and a film container (for worst cases that the film is torn). clean your hands as well.
Check the bottom of the camera for a small button that disengages the motor gear (film release button). now open the film door then use a fingers to carefully pull the film evenly, you may feel like the film is being stuck, and if in case it did not move, check if you have a film release button on the bottom of the camera (usually place right below the film). as you do this feel the track of the film and check for damages that will indicate that the film has been torn because it is not loaded correctly or the motorhead malfunctioned.
now just wind the film back to the canister unless the track is torn off (note to leave the film leader out), once it is out, get the film developed right away.
now if the film track is torn cut it off then place it in the container, then have this handed to the developer and tell them that this is an open film, since it can be developed, partially though, it depends on the cut.
OR better off, you can bring your camera to the developer then tell then the film is broken inside and they will do all these for you.
good luck.
Posted on Jun 25, 2008
    Problem Solver:
  • 3 Answers
This seems to be a much simpler question than assumed by the answer above. Did the first answerer have much more information? The simple answer is: Push down the small "R" button on the back of the camera beneath the display and slide the gray knob next to it to the left. This assumes no problem with the film transport mechanism. Stan
Posted on Aug 19, 2008
How to rewind film on minolta maxxum 5000?
Open door in the dark room.
See if it's already rewinded, but could be a stuck counter
May 12, 2014 | Minolta Maxxum 5000 35mm SLR Camera
The battery in my Minolta Maxxum 7000 died while rewinding. I replaced the battery, but nothing happens and the rewind-button/slide is stuck. How do I reset this slide, so I can rewind my film?
Sorry to hear you're having troubles with your Minolta. First thing I would do is make sure that the batteries you put in our good and that you do have power coming out of that battery box. He didn't mention whether the batteries had corroded or if there had been any corrosion previously. The rewind button on this camera will not reset until the camera again advances. In other words it is an automatic release on the camera fires the first time after a rewind. So as an beginning answer to your question I would check the batteries again make sure that all contacts are absolutely clean and as you may have noticed the battery boxes on the Minolta do pivot. The contacts under the pivot points also have to be clean. If you checked all of these issues and you're still having problems please feel free to e-mail me at, Dave@advancedcamera.com.
Thank you good luck
Aug 10, 2011 | Minolta Maxxum 7000 35mm SLR Camera
I own a Minolta 7000 series that was given to me. I do not have the manual for it. On the front of the camera it also says AF. My question is, how do I rewind the film and take it out of my camera. ...
If it's a Minolta Maxxum 7000, it should automatically rewind the film when finished with the roll. To manually rewind the film, open the card door on the right side of the camera and press the rewind button. Open the back cover by pressing the button in the center of the back-cover release and sliding the release downward.
You can download the manual from
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Feb 28, 2011 | Minolta Cameras
How do you change the film in a minolta x-370n?
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
Dec 10, 2009 | Minolta X-370S 35mm SLR Camera
Camera took pictures to # 7, then the 7 just blinks off and on, then won't do anything else. I put in new batteries, thinking that might be problem. It isn't/ what to do????
Likely its the film tranport motor. If that goes out, the camera cannot advance film. Try rewinding film. I forget if the 7000 had 1 or 2 such motors. Could also be teeth broken/worn out on the gears, but sounds like a trip to the repair shop is in order. If it will not rewind, put the camera inside a zipped dark jacket. Fold the bottom of the jacket to block light. Put your arms in the sleeves and open the camera back. Pull out the film, rewind it into the can.
Oct 16, 2009 | Minolta Maxxum 7000 35mm SLR Camera
How do I change film in my Minolta xg-a camera ?
first push in the rewind button on bottom of camera, then turn the rewind knob to the right to rewind any film that's in the camera. then pull up on the rewind knob to open the back cover.
Sep 30, 2009 | Minolta XG-A 35mm SLR Camera
Wind film?
Behind the LCD screen on the back of the camera, is a a gray button marked "R", and a gray slide switch to the immediate left of that.
Press and hold the R button, while sliding the switch to the left, this can be easily done with one thumb. the display will blink 0 and the motor will stop when rewinding is complete.
-John
Feb 21, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Rewind runs but film still seems stuck & won't rewind-Max 3xi
It could be that there is a broken or missing gear in the rewind. It will spin but not catch. Sometimes when film is loaded it, is not drawing the film across and missing a gear, so it seems like your taking photos and its not. If you sent it to minolta, good luck, they were bought out by Konica, and probably didnt' do a thorough analysis of it.
I have a friend who fixes cameras. Cleans them, lubricates them, and callibrates them,
http://www.cameradr.com/
Hope this helps you
Nate
Dec 30, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
35 mm minolta maxxium 5 w/ a af zoom
after loading new film roll and after taking first snap, automatically rewind the roll and coulnttake any photo,,,,,,,,,
Dec 16, 2007 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Minolta 700si rewind Problems
I dont get it! All I know is that almost all of film cameras rewinds when it reaches the end of film. Find the switch that turns off the autorewind function.
Apr 15, 2007 | Minolta Maxxum 7 / Dynax 7 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
346 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
