Question about Panasonic KX-FHD332 Plain Paper Thermal transfer Fax
HOW TO RECIEVE FAX ?
I just bought a panasonic kx-fhd332 from a garage sale and i had a friend send me a fax but it does not show up it says fax in memory but to him it say the fax has been sent. Could you please help me with this!
    Genius:
  • 2,120 Answers
Try unplugging
Posted on Aug 31, 2008
Erasing Memory from KX-FHD332
Follow page 65 and 72 of Panasonic KX FHD332 Operating Instructions Manual
Memory full
When making a copy, the document being stored exceeds the memory capacity of the unit. Press {STOP} to clear the message.
Divide the document into sections.
Fax/memory full
The memory is full of received documents due to a lack of recording paper or a recording paper jam. Install paper (page 14)
or clear the jammed paper (page 72).
L When performing memory transmission, the document being stored exceeds the memory capacity of the unit. Transmit the entire document manually
Mar 11, 2016 | Panasonic Office Equipment & Supplies
Communication error 43 message every time and with every number.Panasonic fax kx-fhd332
COMMUNICATION ERROR (Code: 43, 44) means that "A line problem occurred". There might be a problem with the phone jack where your fax machine is connected to. Try to connect the telephone line cord to a different jack and try again.
Mar 21, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
Caller ID problem with KX-FHD332
Your fax machine does not actually have CALLER ID, it reads what the sending fax machine has programmed into it. If it was never entered in, you won't see it.
Jan 13, 2010 | Panasonic KX-FHD332 Plain Paper Thermal...
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
How can I turn off the auto answer feature of the pansonic kx fh332. I never want it to pick up and go to fax mode.
Set the fax machine to Telephone mode by pressing
{RECEIVE MODE} until TEL MODE is
displayed.
You might also want to dowload the Operating Instructions for you fax machine: KX-FHD332 Operating Instructions (English) (17208 kb)
Aug 03, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Is there a way to re print a sent fax?
No there is not. You either have to fax them back requesting new copy
Jun 06, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Fax memory full message
Try unplugging the power cord for 30 seconds.
Mar 17, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Panasonic KX-FP153 Copy too dark
Try unplugging the power cord and re-plugging. It sounds like your scanner assembly is going bad.
Jun 17, 2008 | Panasonic KX-FHD332 Plain Paper Thermal...
It will not start printing,or exept printing or copying
Try unplugging the power cord and re plugging in.
If it rings but won't pick up, you may be set for MANUAL mode.
Nov 07, 2007 | Panasonic KX-FHD332 Plain Paper Thermal...
Panasonic KX-FHD332 Plain Paper Thermal transfer Fax Logo
88 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
