Question about Kenmore 62802 Electric Dryer
Dryer stays hot hours after using it
I dried some clothes the other night and when I went out to take the clothes out the next morning the dryer was hot on the top and in the back of the control panel. I unplugged the dryer and took the top off, took the vent out of the back and got as much of the lint I could out of those areas. Some of the lint was black as if it had been burnt. In front of the dryer drum where the inner lint trap is located (once you open the door) I could reach down to the bottom of the dryer and pull out more lint, alot more lint!
So today I tried the dryer again and after about 15 minutes on high setting it got hot again and started working fine. Or so I thought..... An hour or so later I felt the top again and had the same problem...HOT! Why is the dryer staying hot when it's not even on???!!!
  • adriaenssens Nov 11, 2008
    I am having this same problem. Is it a fire hazard?
  • 413 Answers
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Posted on Jun 26, 2008
Why does my dryer have no heat and keeps running when i use the timed heat-sensing selection?
Suspect vent still plugged with lint, leave vent disconnected and run dryer, stay within eyesight when doing this, if the dryer dries the clothes, then look for blockage in the vent pipe to the outside.
Sep 02, 2015 | Crosley Dryers
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
Dryer is heating but clothes are not drying.
Judging by the increasing moisture, your dryer vent is not venting the moisture to the outside. Check your vent pipe for blockages. I had a person a while back with a similar problem, and this person had a lint trap on the connection that went to the exterior of their house, so check that out as well.
May 08, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
Sep 05, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dried some clothes the other night and when I went out to take the clothes out the next morning the dryer was hot on the top and in the back of the control panel. I unplugged the dryer and took the top...
More than likely, the motor centrifugal switch is stuck. You should be able to turn off the element with the timer control switch. If the timer switch is on and the dryer is not running, the element should be off, unless the motor contact is stuck closed. You will have to get to the motor and 'un stick' the contact.Its a bit tricky, you may need help.
Jul 21, 2009 | Kenmore 62802 Electric Dryer
Maytag model# LDE482 electric dryer won't blow hot air
Either the control panel is defective or the dryer heating element is defective.
Jun 28, 2017 | Maytag Dryers
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Maytag MDE4806AYW Electric Dryer won't stay running
Jan 30, 2008 | Maytag MDE4806 Electric Dryer
Kenmore 62802 Electric Dryer Logo
667 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
