Question about RCA D52W19 52" Rear Projection Television
Convergence nightmare I have been attempting to fix my free d52w19 (someone gave it to me)- the convergence went bad, so I went on ebay and bought a new convergence board for it... I have since installed the convergence board, and it still looks exactly the same! I CAN access convergence in the service menu, (so I am guessing the fuse by the FBT is good) but when i try to use the remote to adjust everything, the crosshairs dont move, however, it DOES switch when i push OK to change colors or 2 to change positions. when i go into AUTOCONVERGENCE, it will go black, fill the screen with red, and then go back to the CONV menu with no change.... Help me Obi-won, your my only hope!
  • 4 more comments
  • Josh Crager
    Josh Crager Jun 26, 2008
    Well, I re-soldered the flyback, and all fuses have continuity - still no change. any other ideas?? By the way, thanks for the quick reply!
    also, a tidbit i left out before, the screen is also "sucked in" twords the middle on the top and bottom.. maybe this detail will shed light on a different answer?
    thank you!!
  • Josh Crager
    P.S. It IS an ITC222 chassis as well
  • prettylite Jan 24, 2009
    the picture bows in from all sides plus the tv sometimes gives off like a sparking sound
  • leopardladie Jan 31, 2009
    Im going nuts we have a 51 " or 52" sorry i forgot which it is rca rear projection thats only 2 years old and last year we turned it on and the colors are all out of wack. It looks like a 3d movie without glasses. The 3 color lines are totally off. I remember when we first bought it we had to adjust the colors a bit with the remote but that section isnt on there anymore. We waited so long cuz warrenty ran out and a week later it went bad. Called repair guy today he said about $400, thats nuts. I can repair it myself if someone could please tell me what it is and where it goes. Thanks so much, I gotta fix it to make hubby happy again he misses his big tv.
  • sli20001 Feb 12, 2009
    rca d52w23 were do i find this fuse?? i have back of and dusted it all off ...maybe it is fuse like Im reading??
  •  kelly mayes
    kelly mayes Aug 23, 2013
    you look up a convergence repair kit.. comes with circuit board that has the parts on it that are not working on your t.v. and all the little replacement resistors and instructions how to fix it.. I am looking for one for my model t.v. locating that part seems to be WHY you see all the big screens on the curb.. like trash... if you cant get part to fix it then your hating it.. I am going to start surfing for each PART.. take out my circuit board and look at PART NUMBERS on EACH COMPONENT.. the big convergence Integrated Circuits may be easier to surf for with their part numbers instead of using t.v. model number and searching for whole convergence repair kit..
    Problem Solver:
  • 9 Answers
You will need to replace FL231 and resolder the joints of the flyback. Trust me, I have done this repair multiple times. To check the fuse, you will need to lift one leg up and out. If you pop the cover of the fuse off, the link may still look "ok" but will be broken. A temporary way to test it is to jumper the leads of the fuse with a jumper wire or alligator clips.
Posted on Feb 07, 2009
I had the same problem, I resoldered the fyback (LL008) and changed the fuse (FL231) had my voltage back, but still no convergence. I read in the service manual that disconnecting BW001 BW002 on the Converagence Amplifier board may remove the load on the Convergence Power Supply. I unpluged the TV did remove it and turned the TV on, let it boot up and run for two minutes or more, then shut it down, waited a few minutes. Unpluged TV and I pluged back in BW001 and BW002 connector back in and turned the TV back on and it was back. Some adjustment and had had a great picture back. If this done do it your out of luck, the Convergence Power Supply and Convergence Amplifer Boards are no longer avialable. Make sure that all the flyback leads are resoldered real good.
Posted on Aug 16, 2008
  • dsm340Tech Aug 16, 2008
    Sorry about any miss spelling or any other errors, in my last sent comment, My power was flickering, so I sent it off before the power out. Did not have time to correct
Check the convergence power supply board or the convergence
generator on the signal board
Posted on Jul 16, 2008
    President:
  • 1,284 Answers
If this is a ITC222 chassis then you need to check the fuses that are near the flyback. I would also unsolder all the pins on the flyback and re-solder them as the factory lead free solder tends to crack and cause issues with the convergence. Re-solder it with common 60/40 solder you can pick up from Radio Shack or other places.
Posted on Jun 26, 2008
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: rca d52w19 convergence hell
Did you replace the convergence board or the convergence power supply board? usually one color will be a problem with the convergence board and more than one color means the convergence power supply is the problem. Ebay isnt a good place for boards as you never know if the board is good. You can get the convergence or the convergence power supply boards at the following link along with free shipping and tech support.
http://servicemanuals.vstore.ca/
Slinteriors
  • 8617 Answers
SOURCE: convergence nightmare
the convergence board wuld not solve the problem, you need the convergence power supply board for the ITC222 you can get one at the following link with free instructions.
Posted on Sep 25, 2008
RCA D52W19 it kinda looks 3-d i went to the convergence options but it wouldnt let me move the the arrows even though they are way off. and when i tried the auto covergence it went dark a green square...
I woudl not suggest you personally fix this, but can be and easy fix. there are a few fuses around your flyback transformer that blow. there are three of them next to each other. One to all can possibly be blown. just replace these fuses and this should do the trick. will need to do a screen callibration afterwards. If you decide to do the work yourself, MAKE SURE THE TELEVISION is turned OFF! Flybacks can produce and extreme amount of electricity. And experienced tv tech can have you going in about 1/2 hour.
G-D Bless and good luck
Aug 10, 2010 | RCA D52W19 52" Rear Projection Television
Philips 55PP93 5217 RED CONVERGANCE
If you paid that much for the same repair, man I am sorry. A repair like this should cost no more then a few hundred bucks. OK how much solid state printed circuit board repair experience do you have? If none, NO you should not attempt this repair. If you know someone who does, Great. The convergence amp. IC's need to be replaced. there are two of them. You will need to locate them, order the right ones, as all convergence, Good Luck IC's are not alike, maybe that's why you set went bad again, as cheap or aftermarket type ICs will do this also. Goo luck, If you need more assistance with this, ands can find someone to assist you, or if you can do it yourself, please do not hesitate to get back with me.
Jul 29, 2007 | Philips 55PP9363 55" Rear Projection...
We bought someone's nightmare from a local pawnshop. We did not know the problems we would encounter after reading about our Polaroid FLM-373B T.V. WOW! Any ways we replaced 3 of the capactiors in it. The...
Well, misery loves company, so here is my advice, try and get the entire board(s) from the throw away sets, check out TV repair shops they will maybe even give you some of the bits, or even, let you take them out yourself, Just be polite & direct, and I am sure you will prevail. look om Ebay, check local papers, for busted sets, that hopefully won't have same fault as your. These Polaroid sets are a nightmare.. but when they go, they''e OK. If you only paid $50, well, you have a bit of room to move... :)
Feb 08, 2010 | Televison & Video
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
Problems with 52in HDTV
NO this is a condition known as convergence problems. first question in menu then go to setup and see if the option of convergence is in the menu. is the picture bowed in from the top and bottom. do you have the option of autoconvergence. does it work and how far does it get. there is a common problem with these sets. and may be a simple fix if you can solder a part. so let me know and we will continue to troubleshoot.
Oct 29, 2008 | RCA D52W19 52" Rear Projection Television
Sep 24, 2008 | RCA R52WH73 Projection Television
06 mazda3 keyless remote programming instructions
It should be hit the unlock button 3 times, open and close the door 3 times, the locks will operate themselves twice. Hit the unlock button on the remote and it should program. you should try a remote from the dealer not from ebay.
Sep 20, 2008 | 2006 Mazda MazdaSpeed
Rca d52w19 convergence hell
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
Convergence problem
when you go into menu do you see covergence in setup,if not then it is not your convergence boards,next to your fiyback transfomer this is the power supply board there is 3 small fuses the one in the middle opens FL231 they look like small brown square caps 0.4 amps.
Jun 05, 2008 | RCA D52W19 52" Rear Projection Television
Broken d52w19
Hi ,here is some of the tips found on www.repairworld.com no convergence- replace fuse FL231 near flyback or in front of flyback also solder flyback pins alot of these sets have poor connections,they are having alot of trouble from ribbons that connect from bottom tuner broad going to convergence broad also connectors that ribbons plug into so far there is more infor on the HD52w59 .The next set i get in my shop the first thing is to solder power supply broad,then see what happens so far the 2 sets i have now i havent been able to fix,but im not quiting untill i fix them or throw them back to customers.
Feb 03, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
222 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
