Question about Sony VAIO VGN-N130G/W Notebook
System repair How to run it, where is it?
    Genius:
  • 2,028 Answers
You will to run the repair with your recovery disc or operating system disc. In order to do this, you will have to enter the boot menu or set the machine to boot from CD before the hard drive. If you run a repair it will keep all the drivers, installed programs, and your files. If you have to do a complete reload, then you will have to download the drivers from the manufacturers site and you will lose any installed programs and files. If the hard drive is bad you are going to lose these anyway.
Posted on Jun 25, 2008
All of my running lights and blinkers work and high beams but no low beams on my 1997 Chevrolet TahoeA
Headlamps Inoperative - Low Beams
Step
Action
Value(s)
Yes
No
DEFINITION: This diagnostic procedure should only be used if the high beam headlamps are operating properly and the low beams are inoperative.
Did you perform the Headlights System Check?
Go to Step 2
Go to Headlight System Check
  1. Turn the headlamp and panel dimmer switch to the ON position.
  2. Move the headlamp dimmer switch to the LOW position.
  3. Backprobe the headlamp dimmer switch connector with a J 35616-200 from cavity A to ground.
Does the test lamp light?
Go to Step 3
Go to Step 5
  1. Remove the daytime running lamp relay.
  2. Connect a J 35616-200 at cavity G5 to ground.
Go to Step 4
Go to Step 6
  1. Re-install the daytime running lamp relay.
  2. Backprobe cavity B at the high/low beam headlamp with the headlamp dimmer switch in the LOW position.
Go to Step 7
Go to Step 8
5
Replace the headlamp dimmer switch.
Is the repair complete?
6
Repair the open in CKT 359 (PPL) between the headlamp dimmer switch and the daytime running lamp relay.
7
Replace the high/low beam headlamps.
8
  1. Inspect for an open in CKT 12 (TAN) between the daytime running lamp relay and S120, repair as necessary.
  2. Replace the daytime running lamp relay if no open was found in CKT 12 (TAN) between the daytime running lamp relay and S120.
Jul 24, 2015 | Chevrolet Cars & Trucks
Tip
Startup repair in Windows 7
If you've downloaded Windows 7 (and even if you haven't) it's a good idea to create a system repair disc straight away in case you run into problems booting the OS later on. Click Start > Maintenance > Create a System Repair Disc, and let Windows 7 build a bootable emergency disc. If the worst does happen then it could be the only way to get your PC running again.
on Dec 11, 2009 | Computers & Internet
Can Drivers-Utilities reinstall disc be used to stop Endless Loop Start and Repair found root error Registry is Corrupted. Repair Action Registry Roll Back successful.
Doubtful... You'll need to use a OS Install disc to repair System/Registry files. If you have the System Install Disc, put it in your optical drive while your PC is already up and running. When the Auto-Run prompts, allow it to run, but rather than starting a fresh install, select the "Repair" option... It should then scan your system & settings and replace any missing or broken files. However, if your system can't start at all, place the OS Install disc into your optical drive while it has power then shut down your system. Wait 10 seconds and restart. Boot from the CD and then select the "Repair" option as mentioned.
Good Luck on fixing your system :-D
Apr 05, 2015 | Dell Computers & Internet
The laptop shows windows system 32 configuration file corrupt error how to run laptop?
Hi
Windows system 32 file is part of the operating system and when it is corrupted, you cannot boot up your computer. I suggest if you had a systems back files, use it to recover the missing file. Just load the back up disk CD/DVD into the CDROM, boot up your computer and run it to CDROM and option will display and choose the repair.
If don't have the systems back up disk. Only solution is to reinstall or repair your operating system.
For reinstalling and repairing, insert the OS installer CD in your CDROM and boot up your computer and run the repair or reinstallation process. Follow the procedure.
Jan 13, 2011 | Lenovo IdeaPad S10 - 42312BU Notebook
My pc ask that windows must repaired
system files have been corrupted, you need to repair your system for its long run. You can do that with the windows installation disk(repair wizard). Or download a free system files scanner to check if repair is required or not.
Jan 02, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Running vista ultimate. crashed. exes in System32 not working
first satrt ur system in the safemode and if it starts u will b getting a restore ballon,then u can b able to restore to ur last restore point... if u dint find any restore point,then insert the vista which u had installed before and click on repair instead of formatting...
May 04, 2010 | Microsoft Windows Vista Ultimate Edition
When i turn it on it says run recommeded repair or run normal setup then when i run the repair it says hardware or software missing please select ok to shut down and when I run normal set it just goes back...
it's mean your operating system is failure so just do repair or format Ur OS & re install fresh copy of operating system..but take backup ur document before formatting Your OS.
Mar 25, 2010 | Toshiba Satellite Pro L300 Notebook
Dell laptop will not boot up?
Turn system on by pressing FN and the power button, this should start the system diagnostics. If hard drive diags pass, then new would be boot to the WIndows CD and Run Repair (Vista) or boot to recovery console (XP) once in recovery console, run the command CHKDSK /R
If running Vista repair, you may need to run the repair tool up to 5 times (Each pass makes a partial repair, it make take more than one to complete all issues)
If Diags fail, replace the hard drive.
Dec 06, 2009 | Dell Inspiron B130 Notebook
The please wait then welcome and stays at welcome.
1. Try to boot your computer in Safe mode and run a full system virus scan with your anti-virus software, this may fix the problem. The system will boot in safe mode only if its not a major damage to the file. If the system is not booting in safe mode, then perform system restore. Click start>all programs>Accessories>System tools>System Restore. Restore computer to a date where it was working fine.
2. In case the system refuses to boot up at all, then it is recommended to run a repair setup of windows Xp. To run repair setup, boot the computer with Windows Xp bootable CD and on installation screen, press R for repair setup. For detailed steps see http://www.windowsreinstall.com/winxppro/installxpcdrepair/indexfullpage.htm
Mar 22, 2009 | Dell InspironTM 1501 Notebook
I can't restart my window vista laptop solve plz
Windows Vista is not starting due to missing or corrupt files.
Run Startup Repair using Vista Operating System disc
  1. Place the Windows Vista Media Backup DVD into to the optical drive and start the computer.
  2. Press any key to boot from CD or DVD.
  3. On the Install Windows screen, click Next.
  4. On the Install Windows screen, select Repair your computer.
  5. In the System Recovery Options dialog box, click Next.
  6. In the System Recovery Options dialog box, select the appropriate operating system, and then click Next.
  7. In the System Recovery Options dialog box, select Startup Repair.
  8. The Startup Repair attempts to locate and resolve issues with the computer.
  9. If prompted, Do you want to restore your computer using system restore?, click Restore.
  10. In the System Recovery Options dialog box, click Finish. This screen can vary, dependant on if a problem was found or not.
  11. System restarts.
  12. If the problem was resolved, the computer restarts into Vista.
  13. If the problem was not fixed, the error may present itself again.
  14. Run Startup Repair again.
  15. If Startup Repair runs more than three (3) times, when available, select View advanced options for system recovery and support.
  16. For further troubleshooting, select one of the following options:
    • System Restore
    • Command Prompt
    • Last resort - Recovery Manager. Recovery Manager is not available if accessing WinRE via Vista OS Backup Media DVD
or you can use any software that can repair and recover your windows files.
Best regards
Mar 02, 2009 | Microsoft Windows Vista Ultimate Edition
Sony VAIO VGN-N130G/W Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
