Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Mcculloch petrol trimmer not starting too good and cutting out when u eventuall get it started
    Problem Solver:
  • 5 Answers
Hi
Please try these suggestions if youve not done so already:
  1. Clean the air filter
  2. Check fuel primmer bubble (if it has one pressurizes)
  3. Spark at plug, when pulling cord (When they degrade, some plugs can fire itermittently - check also with a continuity meter) BUY a new plug
  4. Fuel in present in the combustion chamber (use a torch to see inside plug hole if the if the piston head looks wet from petrol) also the smell will definately be strong
  5. You ay need to adjust the carb idling screw to increase idling speed when engine has warmed up.
These things I tried after investigation & worked for me, unit starts up a treat. Hope thisa helps
Aky1967
Posted on Feb 04, 2009
Where do the three petrol pipes connect
http://www.mcculloch.com/ddoc/MCCI/MCCI2002_AAaa/MCCI2002_AAaa_Virginia-MH542_.pdf
Oct 01, 2014 | Garden
Mcculloch petrol strimmer
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
May 11, 2014 | Garden
My brush cutter keeps cutting out why
Is your fuel mixed correctly.? Do you still have good compression.? Is the choke leaver stuck on.?
May 21, 2012 | Stihl String Trimmer Brushcutter Service...
Mcculloch grass trimmer tm 250 will not start no petrol in bulb
You may need to replace the bulb,or you may have dirt in the carb,failing that you may need a new carb kit,eg diaphram etc,also check for dirt in the petrol tank,rgds
Sep 26, 2010 | Garden
Mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Jul 04, 2010 | Garden
My mcculloch petrol hedgetrimmer wont start, the pull cord has a lot of resistance. I have changed the spark plug and cleaned the air filter but still no joy.Interestingly When i remove the spark plug i...
The fact that your engine turns over easily with the spark plug removed simply means that, with the plug removed, there is no compression, so the piston goes up and down very easily.
If it has been a while since you ran the machine, and if you left gas in it, your carb may have gotten gummed up from the gas losing it viability and turning to something like varnish. You might try spraying carb cleaner into the carb (with the air filter removed), let it sit for a few minutes, then try starting. In the future, you probably should get some fuel stablizer (available at almost any hardware store) and add it to the fuel that you use for your small machines. It will keep the gas viable for a much longer period of time.
Hope that you are lucky enough that the carb cleaner, a good dose, will work. If not, you may have to disassemble and clean out your carb. (if you've never done that, a series of digital camera photos so you know where to put things back is a good idea).
Oct 18, 2009 | McCulloch Garden
How do I use the B & D edger and trimmer
This is for a MCCULLOCH TRIMMAC 210, 21CC (petrol/gas Line Trimmer).
http://safemanuals.com/user-guide-instructions-owner-manual/MCCULLOCH/TRIMMAC%20210-%2021CC-_E
Operation of this and other Line Trimmers are all the same with some exceptions with optional attachments.
Aug 31, 2009 | Black & Decker 14" Grass Hog Xp...
Mcculloch petrol hedge trimmer, no petrol seems to be getting into the primmer button, so i can not start it
There should be a strainer on the fuel intake line in the fuel tank. Take it out and clean or replace it, and check the fuel lines for cracks or leaks. If this doesn't fix it, disassemble and clean the primer button. There should be a little one way flap valve that opens to allow fuel to be sucked in from the fuel tank and closes to push the fuel into the carburetor.
Jun 06, 2009 | Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
201 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
