Question about Durabrand DUR7 Portable DVD Player
Dvd reading not reading dvd saying loading but thn says no disc
  • 1 more comment
  • Anonymous Jul 18, 2008
    it sucks
  • nsdobbins Jul 24, 2008
    I have this same problem. I load the disc and it doesn't read it and says, "Loading" on the screen while trying to (continuously) read it. Does anyone have a solution?
    nsdobbins@yahoo.com
  • Anonymous Dec 22, 2008
    I have the same problem with both my Sony and Phillips DVD players. Curiously, they both stopped reading discs soon after being physically moved to another room. Could it be the laser was pushed out of alignment? The Phillips player is only a couple of years old, so I don't think it's worn out. I'm going to try a cleaning disc and if that doesn't work, I might just open the players up and realign the laser heads like someone was suggesting.
I had the same thing happen to a used DuraBrand 7" Portable DVD Player. Check and see if the laser transport is locked in at the top of the track -- which would be in position to read the outer edge of the DVD. The laser transport gets locked into this position and you get "no disc" error messages.
I removed the bottom of the DVD player -- a matter of seven screws -- and moved the laser transport by hand nearer to the center post of the DVD turntable. This cured the problem and my DuraBrand is working fine now.
I have no idea what makes the laser transport move to the extreme outer position and get locked there, but this solution works. Good luck with your own.
Posted on Oct 20, 2008
I also rercieved the same problem...Solution reguarding No DVD removing the seven screws and looking at the laser transport motor colored spindel on the motor should be moved with the greatest care moving it closer to the center where the DVD drive motor is at, then replacing two of the screws that were removed and replacing the battery pack testing this proved positive in reparing the problem......
Thanks PRPLHAZE :-)
Posted on Oct 31, 2008
  • 30 Answers
You may try a CD/DVD OptiDisc Laser Lens Cleaner by Memorex. Hope it helps!
Posted on Oct 18, 2008
2 Suggested Answers
  • 50 Answers
SOURCE: Dvd reading
you will need to get the lense cleaned in the dvd player .
Posted on Sep 17, 2008
I load a dvd in the sylvania sdvd 9009 player and it says no disc after loading
If the DVD loads, there should be something on the display that indicates it is being read (maybe a spinning disc icon). If it tries to read, then displays the "no disc" icon it means either that particular DVD can't be read or the drive has failed. If you try another DVD and get the same result, you can be pretty sure the drive has failed
Dec 16, 2012 | Televison & Video
Sony dvd player doesn't read disc says no disc when loaded
This would indicate the laser pickup assembly is the problem, try a DVD cleaning kit and follow instructions, if no change, far cheaper to replace the stereo.
Mar 17, 2012 | Televison & Video
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD. I...
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
Aug 15, 2009 | Samsung DVD-R155
When I insert a dvd it says no disc
DVD need replesment of optical lens,then its ok
Jul 09, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Dvd player wont load disc
try cleaning the lens first.then load a disk.try a different disc like VCD, CD etc.if only the DVD's are not read, the lens and the mainboard itself is faulty.but, if after cleaning it, it goes ok ,then its just dirty.
May 28, 2009 | Sony RDR-VX530 DVD Recorder/VCR
After disc is loaded, it says "unknown disc."
Is it a pirated dvd? If it is, do you know some dvd players won't read pirated dvds? And if it isn't, then your dvd player may be dirty (the lens). For that you would have to buy a cleaning disk. You can get one at Radioshack. Or maybe what type of dvd type is it? Is it dvd-r, dvd-rw, or what? Some dvd players have trouble reading dvd-rw sometimes.
Hope this helps.
May 08, 2009 | Jwin JD-VD140 DVD Player
Won't pickup the dvd everytime
there are a few possibilties
1 make sure the disc is clean
2 your lens may need cleaning
3 some dvd players don't read burn copies of disc's some just read +R discs some just read -R disc
Jan 29, 2009 | Memorex MVDP1077 Portable DVD Player
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Dvd reading
Sep 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Problem loading dvd
replace the lens of your dvd your problems solve
Sep 18, 2007 | Mustek PL-407H Portable DVD Player with...
Durabrand DUR7 Portable DVD Player Logo
159 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
