Best way is to download the pictures to a computer through a card reader (optional). The blue blank screen could be deleted images using the garbage can icon. Retrieving those images can be done but it cost to have a recovery program used and there is no grantee that the images can be extracted because the card my have been written over or formatted. Once you have your images saved to a computer the memory card should be loaded bak into the camera and the memory card formatted to give a clean working surface for the camera to write new files to.
Hello, the blue screen could be a sign of a defective tuner. If you are using a video input for your DVD or VCR player, do you get the blue screen then? If you do there might be a problem in the color processing circuit.
Your tv is an LCD projection one - in which the image is generated by 3 small LCD screens. The blue dots are pixels from the blue LCD that are dead - always fully open.The only fix is to replace the LCD panel and that is going to cost you around $300.
As in there's blotches of red and green at the edges, but the image is still there?
If so, then your screen may have come into contact with magnets, or maybe the alignments are off (TVs align overlapping images in red, green, and blue).
As always, check with the manufacturer support lines, as they would have specific information for these kinds of scenarios.
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
You will need to repair the convergence circuit to fix the double image. The second issue of the "perfect focus" stopping at 37% will be fixed at the same time. It is halting because the sensors detect no movement of the blue image. here is a link to the part number and how to purchase the board.
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
