Greetings,
The first thing to be sure of is you do have voltage at the motor...once your sure of this. I would advise you to check for a broken wire at every connection block..I have also seen this happen before. The defrost board controls the evaporator motor as well as, the compressor and lights etc..Its located in the fresh food side. The top left has a plastic cover that runs to back of refrig..There are two screws that secure this to the cabinet and two small dimples that go into a retainer at the front of it..Remove screws and slide the housing towards the right side..it will pop out. then you can look at the board and see if showing any burn spots...Its possible to be bad, but look ok////Bruce Denton
Testimonial: "Thank you very much. The problem was the Control. You know your stuff."
