Question about GE Dishwashers
Need side mount brackets gpf65 because of granite counter top, model #ghda485n10cs ser# rm763786b, quietpower3 dishwasher
    Sergeant:
    Champion:
  • 330 Answers
I don’t know your counter situation, usually you have to put dishwasher in a bottom cabinet and mount both side. Suppose you only have one side to mount, you have to go to home depot to buy a 90 degree metal mounting bar, mount the top part to your top granite support board, the bottom side mount to the dishwasher, it should be a ¾” plywood board underneath the granite, you can use ½” screw to mount it.
Hope this can help you,
Posted on Jun 25, 2008
How do secure this DW to the inside top of cabinet... there are no holes to skrew through!
This is sort of strange, you give no info on what kind, model brand anything.
I will try to help anyway though. most dishwashers come with TWO REMOVABLE BRACKETS that clip to the top.
A single short wood screw goes through the bracket into the underside of the counter top.
IF YOU HAVE A SOLID SURFACE OR GRANITE COUNTER TOP, you might have to side mount the dishwasher. You might have to order the side mount brackets from the manufacturer or a parts house. Some stainless models have a little removable plug on each side that will accept a wood screw that goes into the cabinets on each side.
If you need more information please give us the brand and model number of the dishwasher.
Sep 26, 2017 | Washing Machines
How do I mount Kenmore dishwasher model 65515779 to granite counter top?
Joanne,
You need a granite/stone counter-top mounting kit. It will be a metal strip that you can attach to your cabinets and allow you to screw some short screws up into that metal strip. I would think that most major home repair dealers would have something like that. Dishwasher Undercounter Mounting Kit W10426979 The Home Depot
May 13, 2015 | Kenmore Dishwashers
We are installing a dishwasher--have it hooked up but can't seem to get the leveling legs loose so we can adjust the height. Also, the anchoring peices of metal stick out farther than our countertop.
Hello, This dishwasher has the ability to be mounted to the cabinets on either side of the dishwasher.the mounting brackets can be moved to each side. If it must be mounted to the counter top, the mounting tabs can be bent by hand and it will break the front part of the mounting tab. This will shorten the mounting bracket. If you have granite counter tops do not attempt to drill into to the granite counter call a granite fabicator. The leveling feet are hexagon shaped at the top of the of the leveling leg. Remove the front lower toe kick panel. This will allow access to the top of the leveling legs,then use a small cresent wrench or a socket and rachet.Hope this helps.Joe Connolly
Sep 18, 2011 | Frigidaire FGHD2433K 24 in Builtin...
How I prevent the dishwasher from tipping? I have granite countertops so I will need to stabilize without clamping to counter?
Hello Mariebyrne, Solution 1: Call granite fabicator to mount dishwasher to granite top. 15 mins for them solution 2: Check sides of dishwasher for cabinet mounting (side mount). Open door to diswasher look at each side (in front of the door seal) about halfway down there will be some small round button looking plugs. If you see these plugs the mounting brackets need to be moved to the side position.the dishwasher will need to be pulled forward about 6 inches.after the brackets are moved position the dishwasher to where you want it. Remove plugs and screw in to cabinet. Replace plugs and your done. Hope this helps
Sep 17, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
I have a granite counter top and cannot connect the top holding brackets.
A side mount installation kit is available for most dishwashers. Be sure to pre drill the holes in the cabinets to prevent splitting. Sometimes the top mount brackets can be removed and used on the sides, check the installation guide or manual.
Dec 27, 2010 | Whirlpool Dishwashers
How do I properly secure the dishwasher to the cabinets so it does not move when I'm unloading it?
The feet should be properly leveled and either secured from the top to the counter top using 1/2" screws or in the case of granite tops use side mount brackets and pre drill holes in the cabinets to prevent splitting. The side mount brackets usually come with the dishwasher but you might need to order a set. Here is a video on properly installing a dishwasher http://appliancehelponline.com/dishwasherinstallvideo.html
Aug 17, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
Mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Dec 19, 2008 | Dishwashers
Dishwasher tils when door is open because the bracket is roken
There is now a universal dishwasher bracket for just this problem called E-Z DISHWASHER BRACKET. It is available through Braxton-Bragg or ask for it at a local granite fabricator. It is very simple to use.
Sep 11, 2008 | Viking DFUD042 Built-in Dishwasher
Dishwashers Logo
1,350 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
