Question about Alpine CDA-7892 CD Player
CDA-7893 Hello, I am using alpine cd player outside USA. In my country we have both even and odd number tuner channels, I am not able to set even number sistem tuner on my player. It is letting me to set only odd numbers. Is it posible to set both parameters, or at least swich to even numbered channels. I hope you'll help me. Thank you in advance.
  • fpg50 Nov 04, 2008
    will not play music, only displays zeros on the screen
  • 4 Answers
On my alpine deck there is a setting to switch what country you are in. i believe finding that setting would do the trick. is your alpine deck from the us? or was it sold to you in your country from a retailer?
Posted on Feb 06, 2009
How to change tuner to pick up all frequence's eg: goes from 95.5 to 95.7 how do i get it to change to 95.6 thanks jason
It will only tune into odd numbered stations because US radio station only broadcast in odd number stations (ex 95.5,95.7,96.3). You can change the area. Area 1 is North America, Area 2 is other areas. Press "Menu"->"Setup"->"Tuner"->"Tuner Area", then select 1 or 2. After setting, press and hold "Menu" for at least 2 seconds. This may give you the frequency you are looking for.
Apr 14, 2011 | Alpine CDA-9855 CD Player
When I try to tune in the station it only stops on odd numbers and not even numbers. How do I fix that
radio stations on FM are only odd numbers...
such as 102.1 102.3 102.5 102.7 102.9 103.1 103.3 103.5 etc etc.
Aug 08, 2010 | Alpine CDM-9821 CD Player
Will only tune into odd no didgets 98.1 98.3
On many imported cars , the radios have options for the radio to be used in different areas of the world (UK/EUROPE : ASIA : USA+Americas etc. )
These different areas of the world use different  frequencies (with different tuning increments )
If you have a MENU button on your radio , see if you can find the Area  choice option.
Once found , then it is just a matter of switching to your particular  area
Nov 08, 2009 | Alpine CDM-9821 CD Player
Tuner on Odd Frequencies
Hello ashton_dunn, Stations in the US only transmit on the odd frequencies. And most of the receivers sold in the US will only tune odd frequencies. Hope this helps.
Jun 08, 2009 | Alpine CDM-9821 CD Player
AM radio tuner set as MW tuner. How to switch to U.S.A. AM mode?
AM is just another name for MW. The Radio should tune to a strong signal regardless of the frequency the radio is set to. It should also sweep the entire frequency looking for stations. I'm assuming it has a channel scan setting, plus options to set a number for the station. AM/MW are very much dependent on the position of the either internal or external Ariel. If you have the radio in the wrong position or you have some electrical equipment nearby it could block the signal for the station you want, but not affect the others. Which might explain why it can't find the station you want.
May 05, 2017 | Philips DCM230/37 iPod Docking Executive...
RAdio skips two numbers when tuning
You have a US tuner not a European one. Only European tuners can change the even numbers. USA uses the odds. As far as I know, the US models aren't capable of tuning to the evens.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | JVC KD-G310 CD Player
Setting preset channels
Here is the entire owners manual, you can print it out too.
http://vault.alpine-usa.com/products/documents/OM_CDE-7856.PDF
Oct 31, 2007 | Alpine CDE-7856 CD Player
Problems with FM with
That is very typical of tuners designed for the US market; US FM radio stations use only the odd numbers. In most cases, tuners made for the US cannot be adjusted for use in other countries. However, a few have an "area" control that can be switched; usually it's part of the setup menu. Check out your owner's manual, if it's available.
Jul 09, 2007 | Pyle PLCDUSMP74 CD Player
Alpine CDA-7892 CD Player Logo
82 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
