Question about Sharp AL-1641CS All-In-One Laser Printer
Papaerjam lite stays on, no paper jam
Removed paperjam before in fuser section. picker fiingers and press rllr are worn. copier worked ok for a week, then it jammed up. removed papper jam, but misfeed lite stays on. how do reset.
  • Anonymous Mar 12, 2014
    there was a paper jam in fixing unit after removing it E 2561 appeared
  • 3 Answers
It is possible that there may still be a small piece of paper blocking or lodged in the exit sensor area. It is also possible that when removing the jammed paper that the sensor arm became dislodged and thus creating a false jam code.
Posted on Jun 27, 2008
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Error code H5-01 how to fix on a sharp arm350u
That is a repeated uncleared jam in the paper transport. You may have a piece of paper wrapted in the fuser that you cant see, or one of the sensors on the transport between the paper feed and fuser are dirty.
You can try entering doagnostics, you press P * C * or # * C*, that will put the machine in diagnostics. Then press 14, then enter 1 then press enter. That will reset the machine, If the 14 routene doesnt work look for an uncleared jam or clean sensors.
Here is what it says.
H5 01 Content 5-time continuous POD1 not-reaching
jam detection
Detail 5-time continuous POD1 not-reaching
jam detection
Cause A fusing section jam is not properly
removed. (Jam paper remains.)
POD1 sensor trouble, or harness
disconnection
Improper installation of fusing unit
Check and
remedy
Check jam paper in the fusing section.
(winding, etc.)
Check POD1 sensor harness, and
check the fusing unit installation.
Use SIM14 to cancel the trouble
Aug 09, 2010 | Sharp AR-M350U Copier
I get error message "Paper Jam Fuser 07-104" "Open Paper Cover Remove Paper" I have done that and cannot see any misfed paper. What is the proplem?
It could be a couple issues. The picker rollers may need to be replaced. There are sensors after the draw and after the fuser.
Sep 25, 2009 | Dell 3010cn Laser Printer
Canon imageRUNNER C3200 Copier troubleshooting paper jams. The copier will jam, i will removed the jam paper for i can have a fresh start. i will try to copy again and the paper will jam again. can any one...
It could be a few different reasons the printer is jamming.
The pickup rollers could be worn; There could be an obstruction in the paper path the fuser could be bad
It all depends really on where the unit is jamming (Ie where you have to take the paper out from)
If the copier starts to work, and then gets an error but no paper travels into the unit the pickup rollers are the likely culprit.
If the paper stops somewhere in the middle of the copier, then an obstruction within the paper path must exist or some other internal failure.
IF the paper jams at or in the fuser then yes the fuser is the problem.
Hopefully this helps and feel free to add another comment with more info or questions :)
Sep 03, 2009 | Office Equipment & Supplies
Call for service
Cause The fusing JAM is not completely
Fusing unit installation failure
Check and remedy:
Check for jam paper in the fusing section.
(paper winding, etc.)
Check fusing unit installation.
Check the jam sensors in the fuser.
Aug 24, 2009 | Sharp AR-M237 Copier
PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Aug 28, 2008 | Samsung CLX-2160N All-In-One Printer
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Jammed paper
Pper jams are removed from right hand side of copier-remove cartridge and lift green tab, check for paper there.
Paper jams in the fuser section are a real problem with this model the fuser unit has to be removed.
Jun 07, 2008 | Canon ImageClass D880 Copier
Oki c5150 fuser jamming
This tells me the one of the Pickers in the fuser is damaged and causeing this Jam , I would replace the fuser and chaces are this most likely will resolve your problem
May 02, 2008 | OKI C5150n Led Printer
Oki b4300 Led printer misfeed.
No worn picker cause it is getting past paper rego area and stopping at the fuser.Check to see if bottom fuser roller (orange rubber one under metal one) is wrincled or the plastic coating is coming off to the side
If not then one of the paper path switchs is sticking sometimes down and not springing back (common)  when paper has exited area.there is 3 or 4
Oct 18, 2007 | OKI B4300 Led Printer
Sharp AL-1641CS All-In-One Laser Printer Logo
228 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
