Question about DeLonghi DEFSGG36-SS Gas Kitchen Range
DELONGHI GAS RANGE DEGESC24SS COOLING FAN COMES ON NEVER SHUTS OFF
DELONGHI GAS RANGE COOLING FAN COMES ON ALMOST NEVER SHUTS OFF...COMES ON EVEN WHEN OVEN NOT ON
    Sergeant:
  • 275 Answers
Http://www.delonghi.com/ go to this website and select the country you belong to . in there you will find customer services. they will provide you contact number to call. hope this will sort out your problem.
Posted on Jun 25, 2008
    Guru:
  • 1,894 Answers
Its control module fault
u wil need a tech
  • dewan nafees ahmed Jun 25, 2008
    because the control must stop the fan when needed.
    when this is not possible either the control module is not responding to signal or the temperature sensor is not detecting the temperature
    ur problem could lie in either of the places.
    Brigadier General:
  • 3,614 Answers
The switch to the fan could be not functioning as normal, or it was not totally functioning.. it it better to check it right away.
  • micromaster
    micromaster Jun 25, 2008
    if have a background or idea on how to do the work, check at the thermal switch / selector behind the control panel, the connection of the cooling fan is nearly there..
After the oven has been on 1 hour, or so, it shuts down. Also the controls go blank. After the oven cools down, the controls return and cooking can continue.
I think you have a cooling fan issue with your unit, if the thermostats are sensing the unit is too warm it shuts down. So if the cooling fans is not coming on is will happen also. I hope this answers you question. Good Luck
Apr 14, 2016 | KitchenAid KGST307 Gas Kitchen Range
Cooling fan failure on DEFSGG 36 SS.
We do not have this type of information. Contact Sears Direct for parts, they can get parts for most products like this.
Jan 16, 2012 | DeLonghi DEFSGG36-SS Gas Kitchen Range
My DeLonghi CPC 505 Split System Airconditioner stops cooling when the outside temperature reaches 33degr Celsius
Check condenser coil is cleaned. Out door fan motor is working with full speed. If not replace capacitor. And also check Running capacitor.Check gas pressure, if newly charged. Thanks.
Feb 05, 2011 | DeLonghi Heating & Cooling
MY DELONGHI DFS 090 SO OVEN DOES NOT GET HOT FAN COMES ON AND INTERIOR LIGHT
Hi wendy I am having the same problem with mine did you find out what the problem was please thanks kathy, if you could e.mail me kathywhitfield365@msn.com if you did have any luck I would really appreciate it
Aug 09, 2010 | DeLonghi DEFSGG36 Gas Kitchen Range
How do i turn off the cooling fan?
cooling fan is controlled by athermostat on top of the oven.
If it does not turn off replace it
Sep 12, 2009 | DeLonghi DEBIG24SS Gas Single Oven
My Delonghi gas oven takes nearly 45 minutes to preheat!
I would be suspicious of the thermostat. It or the sensing element may have failed.
Jan 28, 2009 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Front fan failure
Call the Delonghi parts and service hotline during normal business hours toll free 866 844 6566 for help on solving your problem
Dec 02, 2008 | DeLonghi DEFSGG24SS Gas Kitchen Range
Cooktop manifold gas line size
If this is brand new go back to the makers of the stove. And ask them why don't do any modification's to the stove it could invalidate any warranty.
Mar 19, 2017 | Kitchen Ranges
Delonghi gas range fan on all th time, almost
behind the control panel, there you will see the thermal switch/thermal fuse, this part is the one holds and trigger the cooling fan.. once this part is broken it could result in system malfunction, like the one you gave encountered..
micro
Jun 25, 2008 | DeLonghi DEFSGG36-SS Gas Kitchen Range
DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Feb 02, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
DeLonghi DEFSGG36-SS Gas Kitchen Range Logo
264 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
