Frigidaire rubber gasket (boot)
You stated that Frigidaire gave you a replacent (redesigned) seal for the door of your front-load washer. Is that replacement any better? I have contacted Frigidaire about mine, and they want me to pay for the labor, but if the seal is the issue, they will give me the seal for free.
I just need to know if the new seal is any better before I shell out the $$ for the labor.
Thanks,
Putter (Puckett, MS)
putterscustomconcepts@yahoo.com
catriver
  • 878 Answers
SOURCE: front load washer
Hitchhiker, you don't have to remove the front of the washer. The original boot was glued in areas around the door. They came out with a new design because of water leakage on the bottom. The new kit, part number 5303937187 comes with a spring that holds it on to the panel. You can do one or two things, if you don't have the leaking problem, glue the boot back on. Or you can order the new kit, it comes with instructions and replace the whole boot. Check it out, it might be covered under service flash #26-758BR. In any event this job can be done by leaning the washer back against the wall to make room between the tub and front panel. You are going to need an assist, it's better with 2 people. Catriver...post back.
Posted on Aug 10, 2006
  • 619 Answers
SOURCE: Replacing the rubber gasket on Kenmore elite HE 3t
probably some rubberize installation are screw to the case or body/ you only need pollout are screw driver philips or flat .
Posted on Jan 10, 2008
  • 1073 Answers
SOURCE: replacing the door gasket on ge front load washer
very hard to replace if you hav not done it befor to get it installed correctly
Posted on Apr 28, 2008
jsrock516
  • 5911 Answers
SOURCE: chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Sep 02, 2008
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Posted on May 25, 2009
How do I replace the front door rubber gasket and seal ring?
Greg, new seal but need to know how to swap it out. Check the attached links,instruction and guides, If you want to google your make and model Washing Machine door seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Washing Machine Door Seal
How to replace washing machine door seal on Hotpoint washer
http://www.how-to-repair.com/help/how-to-replace-whirlpool-washing-machine-door-seal
How To Replace Front Load Washer Door Boot DIY
Jul 25, 2016 | Washing Machines
How to Replace rubber seal on front load washer
The rubber seal on your washer and similar front loading washers is a relatively easy repair. The seal is held onto the front washer panel and the fixed inside washer drum with separate spring-loaded rings that are reusable. So, don't throw them away! You need to remove the front ring from the front panel before you can remove the front panel. With the ring removed the gasket should be pushed into the washer; noting any drain holes, so that you can reinstall the new gasket in the same orientation. Once the outer ring is removed and the front panel is out of the way, you will have access to the ring holding the gasket to the drum. After the inside ring is removed, the gasket should pull off the fixed washer drum. You are now ready to install the new replacement gasket.
The amount of disassembly of the front of the washer is your option if it interferes with the installation. The door is usually heavy and it is useful to remove it from the front panel. Usually, a couple screws holds it in place. Removal of the front panel may also involve removal of the top of the washer and moving the control panel out of the way so that you can access the screws holding the front panel onto the frame of the washer. The locking latch may have to be temporarily removed but can be left in place if you simply push the front panel out of the way to have access to the inside gasket ring. It is useful to take pictures of each stage of the disassembly process to make sure your reinstall everything as it was.
Installation of the gasket starts with reattaching it to the fixed washer drum flange and then replacing the spring-loaded ring to hold it in place. Make sure the gasket orientation matches the original position. After the gasket is attached to the drum, you can now reinstall the front panel. If you unscrewed the latch mechanism when you took off the panel, now is the time to reinstall it as it can be manually held in place behind the gasket. The door can usually remain off the front panel until installation of the gasket onto the front panel is complete. Now bring the gasket forward and reinstall it on the flange of the front panel; secure it in place with the spring-loaded ring. Your gasket is now reinstalled. Simply reinstall the door and your repair is complete.
Tools needed include a blade screwdriver to help pry the rings off the gasket seal and one or two specialty screwdrivers (usually Torx or Philips) to remove the front panel.
Aug 05, 2014 | Frigidaire Washing Machines
Removing outerseal on my frigidaire front load w as sher
Are you asking about the rubber door boot/seal??? The outer edge is held on by a spring loaded wire that runs around the door opening. You can see it if you lift the outer edge of the boot close to the painted cabinet front. The inner edge of the boot is help on by a very big hose type clamp. Some models you can get to it through the opening after you remove the outer wire. Some models need the washer top removed to get to the clamp screw.
Jul 06, 2014 | Frigidaire ATF6000ES Front Load Washer
Basket rubs on door boot seal.
Be sure both lower and upper halves are correctly connect together
May 01, 2017 | Frigidaire Washing Machines
What is round thing in boot
Hello ladybug4527 - From what you have described it seems that you are speaking about the gasket (rubber seal). If so and if it is leaking, contact a professional to move forward accurately because it will need replacing.
Dec 16, 2012 | Frigidaire ATF6000ES Front Load Washer
Mold in the front part of the rubber gasket
to much soap powder, do boil wash with nothing in machine was a month and this should clean it up or replace door seal
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Rubber Gasket
In the future, leave the door open to dry the washer out between uses
Oct 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
233 people viewed this question
Top Washing Machines Experts
