Matsui tutv1 freeview box, has power going in, but will not turn on, has a red light above "remote" but no green light above power
chrispurs1
  • 372 Answers
SOURCE: freeview box
Hi.
Go to this site I wrote an article about repairing remote controls.
http://www.ehow.com/how_2094701_tvvcrcabledvd-remote-control-quick-easy.html
http://dysonmanuals.llc.nu/
Chris.
Posted on Mar 04, 2008
Benimur
  • 6966 Answers
SOURCE: Hi! My digital box - Matsui
Initially and assuming there was a momentary power interruption, this it is possible that the system has just a glitch and all it needs is a reset. Unplug from the mains for an hours or so to dissipate any residual power and thereafter try again.
Should this be not corrective, then it is possible that the unit has sustained a hardware fault and therefore would require opening up. Further, it needs familiarity with electronic components and circuitry, use of a DVM and a soldering iron as well as access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable doing a DIY, then perhaps your best bet would be to call it in for service.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 06, 2008
  • 3 Answers
SOURCE: remote not workin
what's happened here is the cm61 ng and the reciver box have lost there connection you will have to "rebind" them then it will be fine -
THE BINDING OPERATION DESCRIBED BELOW IS REQUIRED IF:
· Any of the system components (room unit or relay box) are replaced
· HC60NG has incorrect or no binding data stored (e.g. when pre-bound system pack components have been mismatched)
· Interference with the RF signal has caused a communication failure
During the binding procedure keep approximately 1m distance between the room unit and the HC60NG
1 Turn off mains supply to HC60NG for 10 seconds. Re-connect supply.
2 Press and hold the HC60NG push button for 15 seconds to reset previously stored data. The red LED will start to flash at 0.1 s on/0.9 s off. Release the push button.
3 Press and hold the HC60NG push button for 5 seconds to enter the binding mode. Red LED flashing at 0.5 s on/0.5 off confirms the binding mode has been entered.
4 Move the CM67NG slider to the OFF position (CM61 push the OFF button) and press the TEMP , TEMP and PROG 1 buttons together. The CM61/67NG will display InSt.
5 Press the i button to send the binding signal. The red LED is switched off on the receiver box to confirm the successful binding operation. If the red light still flashes push the repeat steps 1-3 and press the the i button until binding is successful.
hope this is helpful
Posted on Feb 16, 2009
  • 3 Answers
SOURCE: thomson dti 6300 freeview box will
What to do: if you have a solid amber light If the power light on the box will not change from solid Amber to solid Red then it is possible that a problem has occurred with the current in use software. Before attempting a fix, power the box off and on at the power socket and then wait at least 5 minutes for the solid RED lamp to appear.
If it still remains solid Amber and the box will not come out of standby to ON (Green light) then this can be corrected using the software revert procedure which is done using the box front panel buttons as follows:
1. Remove power to the unit by removing the power cable from the back of the box.
2. Wait 20 seconds and then restore the power cable while pressing the standby button repeatedly on the front panel of the box.
3. Release the standby button immediately when you see a lamp flash on the box's front display, and then immediately press the following front panel arrow buttons in this sequence:
- Menu
- OK
Note: you have to do this quickly and in sequence
4.The Orange light will flash and the STB will then reboot and should return with the previous version of software.
5. The box will now be running with the previous software version but it will automatically update with the latest version within approx 2 hours and you will be notified by message which will appear in the Message area within the Main Menu.
If you're still having problems please call 08444 159 159 and a member of the Technical Team will be happy to help.
Posted on May 06, 2009
dsacco86
  • 1077 Answers
SOURCE: The tv will not turn on with either the remote or
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TV made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 13, 2009
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
How do I wire a remote door lock to my 1995 mitsubishi eclipse , what are the wire colors for the power door locks?
Hope this helps. It's for a 2004 eclipse remote start.
12volts white/red (40A) + ignition harness
Starter black/red + ignition harness
Second Starter N/A
Ignition green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory blue/red + ignition harness
Second Accessory blue/black + ignition harness
Keysense blue/red ignition harness
Notes: This wire rests at ground, and goes to an open circuit when the key is inserted into the ignition cylinder.
Power Lock purple - pin 33 at ETACS ECU
Notes: The ETACS ECU is attached to the back of the fuse box.
Power Unlock lt. green/red - pin 34 at ETACS ECU
Lock Motor lt. green 5wi pin 19, 28 pin plug below fuses
Unlock Motor green/red 5wi pin 22 at ETACS ECU
Parking Lights+ green/white + pin 2, 15 pin plug above fuses
Parking Lights- N/A
Hazards green - pin 55 at ETACS ECU
Turn Signal(L) green/blue + pin 8, 15 pin plug above fuses
Turn Signal(R) green/yellow + pin 13, 15 pin plug above fuses
Reverse Light red/blue + pin 9, 43 pin plug in driver kick
Door Trigger see notes - see notes
Notes: The driver door trigger is lt. green, pin 6, in a 15 pin plug above the fuses. The passenger door is lt. green/black in pin 65 at the ETACS ECU. Use both wires and diode isolate each.
Dome Supervision green/orange - pin 1, 3 pin plug above fuses
Trunk/Hatch Pin red - pin 62 or 37 at ETACS ECU
Notes: It is in pin 62 on the coupes, and in pin 37 on the convertible spyders.
Hood Pin green/red - pin 24 at ETACS ECU
Trunk/Hatch Release green/white 5wi pin 32 at ETACS ECU
Power Sliding Door N/A
Factory Alarm Arm lt. green/black - pin 42 at ETACS ECU
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm orange - pin 25 at ETACS ECU
Disarm No Unlock blue/red - pin 27 at ETACS ECU
Notes: Meter this wire while turning the key in the hatch/trunk key cylinder.
Tachometer white or black/white ac engine speed detection connector
Notes: The engine speed detection connector is a single pin connector in the fuse/relay box under the hood.
Can also go to one of the ignition coils or the distributor assembly and use the black/blue or white/green wire.
Wait to start N/A
Brake Wire green/orange + brake pedal switch
Parking Brake yellow/green - parking brake switch
Horn Trigger lt. green/black - pin 44 at ETACS ECU
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Good luck.
Mar 02, 2010 | 1995 Mitsubishi Eclipse
I cant get my durabrand freeview box to work.
i have pluged in all the plugs to be in and all in the right places but i have no sound but im getting a picture ??????
Nov 22, 2009 | Televison & Video
Bought second hand goodmans DGB3 freeview box, but although batteries in remote control are fine the unit will not switch on. The red light at front of the freeview box wiil not turn green? Any ideas would...
You must mean the GDB3, Goodmans never made anything called a DGB3.
There's nothing you can do Tony, you've bought a dud.
The GDB3 sold new for under £15 in many outlets and I bought two of them for £10 each; at that price it's not designed to be repaired and failures when under warranty are just binned and replaced by the retailer/manufacturer. Even a replacement remote control costs more than the box originally cost.
You've been unlucky and bought unwisely on this occasion, but don't let it put you off Goodmans in general as they're generally more reliable than many others at the same price level. Don't buy another used Freeview box though as there are many which are out of date and incompatible with the latest Freeview technical standards. You can still buy new boxes for under £20 if you shop around.
Nov 10, 2009 | Kitchen Appliances - Others
Digilogic free view box will not switch on just get red light on
HELLO
Before writing off the freeview box, have you changed the batteries in the remote control? The batteries you get with these units are questionable and they are usually rubbish quality anyway. If you have then it may be a remote problem - check the battery contacts - have the batteries leaked or corroded the contacts in any way?
If all is well, try putting the remote next to a radio with medium wave or long wave on (any AM radio will do). Press the power button on the remote and tune through the radio while doing it - you should hear a pulsing noise.
If the remote is OK then it is certain that your freeview box has gone down and a new one will be needed. I know this reply is long-winded but you would be surprised the amount of times things point back to the remote and not the box. Always try the obvious first!
Hope this helps!
Sep 01, 2009 | Digi Televison & Video
Unable to programme the matsui to my Pentus TV
With your model number at hand, check the Matsui website for a later code list. If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes. At best, these should be called (honestly) 'multi-brand.'
Apr 08, 2009 | RCA 3-Device Universal Remote with...
Just installed new tvonics250 freeview + box
I have one of these boxes and one of the things which has caught me out a couple of times is that the remote can control three devices. To turn the Z250 on and off you may need to press the DTR button at the top of the remote first. When you press the on/off button on the remote the DTR button should light up red to let you know the signal is being sent to the Z250.
You are probably aware of this but just in case you weren't
Mar 02, 2009 | TVonics Televison & Video
Philips DTR 200/05 Freeview box
Could be box power supply failure
Oct 20, 2017 | Philips Televison & Video
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
