Question about GPS
Does nuvi 680 support mini SD memory cards or only SD cards?
    Sergeant:
  • 250 Answers
Hell hbraude,
The Garmin Nuvi 680 appears to support only the SD, not the mini SD format.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jun 25, 2008
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
Will not let me enter an address.....shows NO MAP DATA AVAILABLE?????
update failed or was corrupt or memory failed or wiped just reconnect to pc an let it update again
May 09, 2015 | Garmin nuvi 1100LM 3.5" GPS w/ Lifetime...
How do i install an sd card in my garmin nuvi 1370T
I have a Nuvi 680. I bought a 4G SD card for more storage. Yesterday Garmin sent me a new map to install and now the Nuvi is telling me there is not enough space. Can't be! Nothing was ever installed onto the SD card since I only put it into the Nuvi today. Help, what am I doing wrong?
Apr 05, 2012 | Garmin nuvi 1370T Car GPS Receiver
How to take a garmin nuvi 680 off usb mass storage mode
when you go to tools/settings there is an option for the sd card and you may take it off usb mass storage mode. or simply take out the card and put it back in.
Mar 26, 2011 | Garmin GPS
How instal maps on sd memori card for garmin nuvi 250
Hello
Insert the memory card into the memory card slot on Garmin Nuvi 250 GPS device. The memory card slot is located on the left side of the device. Push the card in until it clicks. (If you inserted a memory card that already has pre-installed maps and files, there is no further action required. The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable. The mini-USB connector will need to be inserted into the rear of the Nuvi 250; the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX formatted Waypoints and other mapping-related files. Right-click on it. Select "Copy."
Select the "Computer" folder from the computer's desktop Start menu. Double-click on the "Removable Disk" drive that represents the Garmin Nuvi.
Right-click in an empty space within the drive and select "Paste." The files have now downloaded to the memory card and will be accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
Dec 06, 2010 | Garmin nuvi 250 GPS Receiver
Hi, have my gps garmin nuvi 350 i losse my memory card , i buy new one , i wan free sofware download dirction trafic in my new memory card
You have to purchase the external traffic receiver that plugs into your side mini-USB port in order to receive traffic information. This is not possible on a SD card.
- Jim
SHARCNET-USA
Jan 02, 2010 | Garmin nuvi 350 GPS Receiver
For Nuvi 260w what are the uses of a SD card?
use this card to store photos and other info u dont want to store on your harddrive
Mar 22, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
My laptop won't show my Nuvi 680 as a mass storage device
I have a couple of ideas based on the information you gave:
1. That Nuvi has an SD card slot.  If your PC has a memory card reader, you could insert an SD card into the machine, copy whatever you want onto that, and then pop the card into the Nuvi.
2.  While the Nuvi is hooked up to the PC goto the hardware device manager (In XP right click -> My Computer -> Properties -> Hardware tab -> Device manager) and see if anything has an ! or a ? next to it.  If so, that's probably related to your Nuvi and resolving that usually involves reinstalling the driver or updating to the latest driver.
More detailed info on what you're trying to do and the result of the above could get a more specific fix.
Nov 19, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 650 660 680 6XX SD Card PNY 4GB SDHC Works
just got my A-Data 8GB card today and proceeded to load it up with 7.2GB of MP3s (nearly full capacity).
I timed with my wrist watch the bootup times and there was no difference in the boot times whether the SD card loaded up with MP3's was inserted in the unit or not. What did change is that even one minute after booting up the songs wouldn't show up in the "MP3 Player" window, it just had a blanked out browse button and a generic icon like it has when no music is loaded.
It took a full 90 seconds or so for the MP3 player to actually become responsive and show my selections, but after that it was working normally (from what I can tell).
Best Regards,
Jan 07, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
101 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
