I have a Mac. Just bout a linksys router. Cannot play set up cd. What should I do?
  • 2,794 Answers
Don't use the setup CD. It can cause a mess anyways if your computer could read it. Just plug the router into your mode using the correct jack. If you need to any admin work on the modem, the default IP address is:
http://192.168.0.1
user id is admin
password is linksys
The instructions on the router are explained on the right side of the screen.
If you want a manual you can go to linksys.com and call up your model number on your router and download the user manual that way.
Posted on Jun 25, 2008
Trying to set up e3000 router on iMac lion and keep getting window saying unsupported os need mac os x 10.6.1 or later. I have 10.7
Try to setup router manually.
You don't need to run the CD.
Open the setup page of the router and change the settings manually.
See How to setup Linksys E3000 router.
Aug 16, 2011 | Linksys E3000 Wireless Router
I am using a macbook air 11inch. no cd rom hence could not run the cd installer. I copied the files to a usb flash drive but am unable to install using that. please advise what steps to take.
you can still connect you mac to your linksys even without a driver.
your MAC have a button that say ASSIST ME on the set-up screen for the wireless connection.
ASSIST ME button will be the one going to show you how to properly connect your MAC to your router.
Apr 09, 2011 | Linksys WRT120N Router
Set up of new linksys
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
I recently got a Mac desktop and my Linksys router disk will not open up. Do I need a router that is made for Macs or is there a way to configure the Linksys?
Hi, You are correct. The CD is not compatible with Mac. What you have to do is Configuring the Router Manually using the Web Based Configuration panel.
How to:
  1. Open your Web Browser
  2. Type http://192.168.1.1 in the Address Bar and hit Enter
  3. If you have changed the address somehow you have to enter that (Router's IP - Default Gateway)
  4. Here is a small guide to Fine your routers IP address in case of that you are unable to access
  5. Enter the user name (default user name is blank- means no user name. Just leave it blank), Default password is admin.
  6. Now you can configure the Router using the Menus.
  7. Make sure that you have Saved your settings before Exit the Web Based Setup.
  8. Make sure that you have changed the Default Password.
  • If you can’t access the router’s web-based setup page, please check the following: cable connections, router’s LEDs, IP address, and connectivity.
  • Connecting Devices Together
  • Ensure that you have an Active Internet Connection and connect the modem to the router’s Internet port and the Mac to any of the four Ethernet ports.
  • Checking the Router’s LEDs
  • After connecting your modem and Mac to the router, check the lights on the front panel of the router.
  • Checking the Router’s IP Address
  • To find a Linksys router’s Local IP address, you have to check the IP settings of the Mac
  • Checking the Mac’s Connectivity with the Router
  • Ensure that the Mac is properly connected to the router.
You can download the Manuals from here to learn how to do Advanced, Customized Configurations.
Note: Please select the appropriate Hardware Version.
Thanks for contacting Fixya! Feel free to ask any questions if you face trouble with the setup. Please rate the answer as well!
Jun 22, 2010 | Linksys Wireless-G WRT54GS Router...
Cant set up router on new macbook pro
Are you trying to run the CD on the MAC computer. CD will not work on the MAC computer. But you can set up the router manually without the CD. Are you able to go online on any other computer . If your router is already set up and you are trying to add MAC computer to the network then you don't need to run the CD. you just need to add the computer to the network. If you are trying to install the router for the first time then you can do it manually. Click Here for step by step solutions
Nov 15, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Installation linksys wireless-g router
In order for you to setup the WRt54G to work with your Ibook you nee d to manually configure it since the setup CD for the WRt54G wont run on your MAC computer, In manually configuring the router you need to access the setup page of it and there you can set it up, I will advice you to contact Linksys tech support so one of their tech can walk you through with the process the number 800-3267114 they are open 24/7...
Hope that helps...........
Oct 10, 2008 | Linksys Wireless-G Broadband Router
How to install this Linksys wireless-G WRT54GS with a Mac?
you can configure that router without using the bundle CD. the default ip address for that router is 192.168.1.1. open internet explorer then type the ip address which is 192.168.1.1. then the default username is "admin" (without " ") then password is "admin" also. then you are now on the linksys webpage and you can configure there. it is much easier to use rather than using the bundle CD.
hope this can help you!
good luck
charles
Dec 01, 2007 | Linksys Wireless-G WRT54GS Router...
Installing with mac
good luck
charles
Nov 30, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
