Question about Creative Labs ZEN Vision:M Digital Media Player
USB Lines where are these lines you speak of?
  • Andre Pinho Jun 25, 2008
    I tried different usb cables.. its not the cable...
  • 2,071 Answers
Look inside your usb you can see four strip lines it means four wires connection,but its not line inside of usb cable have the problem.. the problem is in usb socket of your zen the connection inside maybe one the connection is crack thats why cannot recognize,, this the common problem of usb socket cold or crack joint solder,this cause by plug and unplug ...this i mean i already incounter like this problem .,use a hot air to resolder the joint try this option..if my help to solve your problem rate me as fixya...thank you in advance...
Posted on Jun 25, 2008
  • LORETO LACARON
    LORETO LACARON Jul 18, 2008
    the problem is not in the cable i mean...the problem is in the circuit board connecting the socket of the usb, maybe it crack or loose solder needs to resolder again.
Why does my gmail have lines and lines of numbers underaddress
Usually those extra lines come from HTML and plain text email conversion by Gmail's servers. There is nothing to be alarmed by, if the above is the case. Generally speaking you're likely looking at the header code of an email when such lines appear beneath your email address.
If it's causing a problem or simple annoyance you can change your preferences to not receive or send HTML email, which usually has worked for me in tackling the same problem on my own Gmail accounts over the years.
Dec 01, 2015 | Apple MacBookAir A1370 -19648
Need to know how lines run from oil tank to oil filter
Technically speaking.....NONE!
In reality, an oil line runs from the oil pump return line fitting to the oil filter, and FROM the oil filter TO oil tank return line fitting.
Nov 21, 2013 | Motorcycles
My kenmore coldspot refrigerator sounds like it is backfiring. Air in the line?
If it is the water line you speak of the I would just let the water flow until the lines are clear. Otherwise I would be looking at the fan motors mocking the noise. There is no possible way for air to get into the refrigeration lines. Good luck
Sep 08, 2012 | Kenmore Refrigerators
My valve from the compressor is leaking can I replace the valve or do I have to replace all the lines coming from the compressor
If you are speaking of the tank check valve just replace the valve. I don't know why you would have to replace any of the lines unles they are broken or plugged with some type foreign material.
Jul 24, 2011 | Air Tools & Compressors
Phone lines are not rolling over to the other lines, also when retrieving a call from line 2 ..I can here the person on hold but not able to speak with them.
The rollover trouble is a service provider issue, you need to call your service provider to report it. The second trouble could be related , I would report it to the service provider also. Once the rollover rissue is fixed, test for the second trouble again.
Jan 24, 2011 | AT&T ATT-974 Corded Phone
Need diagram on changing brake lines on a 1995 Chrysler Cirus
There really isnt any diagram available for what you speak....simply make the new lines follow the path of the old lines.
Nov 16, 2009 | 1995 Chrysler Cirrus
Lines on webcam and person I'm speaking to cannot get picture
I HAVE LOST THE CD OF MY LOGITECH WEBCAM SO HOW CAN I SETUP THIS CAM PLZ HURRY UP SUBMIT THE SOLUTION.
May 13, 2009 | Logitech Quickcam Chat Webcam
Squiggly Lines at Power On
Generally speaking, this type of symptom is caused by AC hum leaking throught the power supply. This can be due to a bad filter cap. Since this clears up after a while, I'd start by looking for poor solder connections in the power supply area. If you can, check the caps in that area as well. I'll research this a bit and try to get you more details.
Dan
Nov 06, 2008 | Toshiba 42H82 42" Rear Projection...
Wavey lines
This may be a problem with the TV rather than the DVD. Usually wavy lines are caused by some of the AC signal leaking into the video signal. It is possible that the DVD player power supply is the source of this as well. Check the filter capacitors in the power supply of the DVD player first.
Dan
Dec 11, 2007 | Sony DAV-S500 System
Lines appearing on camera and images
Chwck the Samsung website -technical Support team -especially if this is a recent purchase. But generally speaking this is a no repair situation.
Jun 11, 2007 | Samsung Digimax V50 Digital Camera
Creative Labs ZEN Vision:M Digital Media Player Logo
32 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
