Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My RCA D52W20 is broke! Please Help!
Okay, so from previous answers of yours I've decided I have a convergence problem. I do have the convergence option on my menu screen, but still do not know how to fix it. Also, if I buy the part, is it easy to fix yourself? Or should I rely on a professional as the piece looks pretty complicated. Any help would be greatly appreciated. Thanks SO much, Jen
  • gsbright Sep 02, 2008
    I do not have the convergance option in my settings menu. Is this an easy fix or a high cost high trouble kind of issue? My TV is about 5 yrs old.
    Genius:
  • 1,030 Answers
Ok since you have the option. this may get more complicated than you want ... it will probaly be converge amp or power supply.. if so it will have to be replaced.. when you do that it will have to be adjusted in service mode... even tech have difficulty in doing this adjustment... take me sometime over hour to adjust
Posted on Jun 25, 2008
I have a rca d52w23 and it is stuck in zoom. The auto format option doesn't show up at all,anywhere. How can I get it back?
Check if the convergence menu option is also missing. If so this may be related to a common convergence failure on these models. You can get and RCA convergenfe repair kit from sites such as www.TvRepairKits.com and others.
Apr 12, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
I own a RCA d52w20 and the convergence is terribly bad. I set it up, used auto convergence and even went to the service menu for the 25 point setup. But my screen is still terribly bowed and i cannot find...
Try this with TV off Press and Hold CH- VOL- at same Time Hold untill TV comes on.
Then you should be in Factory setting menu, it will either corect the Problem its self or go straight to Service Menu for Techicians.
Feb 24, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have rca rear projection hdtv and convergence is messed up looks like 3d image. Convergence option has disappeared. Help!!
Very easy repair. You need the RCA repair kit called the ITC222 and ITC222A convergence option missing repai kit available from www.tvrepairworld.com the kit contains the parts and the CD with repair instructions.
Aug 03, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 convergence aspec ratio and sound problem
Did you replace small fuse beside fly back?. resolder fly back pins. Maybe liquid coolant alround chassis or yokes.
Apr 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52W20 red convergence problem
Do you see in Menu go to setup look for convergence if it is not there you have a open fuse 400ma FL231. Try This place for Parts http://servicemanuals.vstore.ca Let me know if you need anymore help.
Dec 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence off on Digital Cable
convergence for the rca itc222 is set individually for digital and analog tuner. Most of time the set will have to be converge in service mode. as a tech i would not recommend getting intoservice mode. but the key is the the convergence has to be set indiviadually for each tuner. You could try autoconverging in digital or even manualy converging
Jul 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model #D52W20
Its either the convergence power supply or the convergence board that you need to replace. Go to this site and leave them an email with your model number and what the symptom is they will be able to tell you for sure.
http://servicemanuals.vstore.ca/
May 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Converges problem for my RCA 52
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
