Question about Vacuums
I am having trouble finding a filter and filter lid for Hoover FloorMate 3060. It isn't the same size as the others.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=706677
Generic problem for all Vacuums
posted by Bud1dog on Jun 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. the best way is to order the part from your local vacuum cleaner dealer in your area or to contact the parts dept @ Hoover Factory and one or the other will order or send the part out or you UPS or for pup @ the vac dealer. Please include the model 3 and the ser # with your request. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 25, 2008
How do I Replace reservoir and tubing assembly on a hoover floor mate?
Hello, this is Ava with Think Crucial.
You may check the online manual for Hoover Floormate in this link: Hoover FloorMATE Hard Floor Cleaner Owner Manual Also, you may call Hoover for assistance which is 800-944-9200
You can order replacement filters for your Hoover Floormate directly to us. You can check the filters in this link: http://www.thinkcrucial.com/search?type=product&q=hoover+floormate
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 13, 2016 | Hoover Vacuums
New hoover floormate deluxe does not seem to be cleaning tile floor
Take it to your local Hoover warranty station. You have a one year warranty. These new machines are giving some trouble.
Feb 19, 2015 | Hoover FloorMate Deluxe Hard Floor Cleaner
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
My Floormate isn't sucking up the water either on the cleaning or the dry cycles. New in February. Can't find my manual.
The most common reason for a lack of pick up is that the plastic filter cover on top of the dirty water recovery tank is missing. The cover is clear plastic with a large hole in it that seals against the motor inlet.
May 16, 2011 | Hoover Vacuums
I have a hoover floormate h-2800 that does not suck up the water
this is a great vacuum. however it does require an extensive cleaning every now and then. diaassembly is required for this. there is a hose that goes from pick up to the tank. make sure this is clear. also your filter should be clean and dry.
May 20, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
I can't find the cleaner?
The Lysol/Hoover Floormate is no longer available. Substitute Hoover floor to floor cleaner.
Apr 01, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover FloorMate won't pick water up
Check for the filter in place and it also requires a filter lid for proper suction or it will not work
Jan 23, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate 3060
You should first check to make sure that the machine is set on wet pick up and not dry. When in dry mode ( the front foot pedal on the left side) the machine is held slightly above the floor. When is wet mode, the squeegees drop down to the floor. The other problem may be the wheel assy is broken. Turn the machine over and check the black plastic wheel carrier at the back of the assy to see if the pivots are broken.
Jul 02, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Won't suck up water from floor
1. Check all the tubes from the nozzle to the collection tank and make sure they are not clogged up. I've had tht happen pretty bad before. 2. Check the squeegee. If it is damaged or torn, replace it.
Aug 27, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
43 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
