Question about Panasonic KX-TG2740 Cordless Phone
Programming old handsets to a new base
I bought a new base. The handset that came with it works. I bought an extra new handset. I programmed it just fine.
I have 2 other handsets that were programmed to the previous base which no longer works. I want to use my 2 old handsets with this new base. How do I program them?
  • 79 Answers
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Posted on Aug 20, 2008
Unable to change handset registrations from old base to new.
Hello Linda,
See if my FixYa Answer from this previous post helps to Deregister and Register your old handsets to your new base.:
My phone says no link to base but am right beside it
Regards,
-Ellsworth
Mar 25, 2017 | Panasonic KX TG4031 Cordless Phone
Bought a replacement battery for extra handset and used the adaptor from the base unit to try to charge the battery. This did not work. Charging notice did not appear in the display window and the charge...
:.. extra handset ..." implies you have another handset. Try the battery from that handset in the "extra." If it works, the replacement battery you bought is defective.
Sep 17, 2017 | Panasonic KX-TG6072B Twin Cordless Phone
CWD4900SE - We have just bought a refurbished extra handset but it has OUT OF AREA on the screen. We have lost our manual - is there something we need to do to get the new handset to be recognised by our...
You shouldn't have to do anything special, just place the new handset into the main base station so it can sync to your frequency.
If that's not working, then the refurbished unit is defective and you should exchange it.
Jan 14, 2010 | Cable_and_wireless CWD4901 Cordless...
Can I use handsets from another DCT 748 unit to expand my DCT 748
Short answer:
No. This model of phone can only support 4 handsets. If you need more than that, you will need to have a second base unit.
Detailed answer:
One of my handsets went bad, and I just bought complete DCT748-4 package from a seller on eBay for a very good price. This set was used, but in very good condition. I didn't need the whole set - just one handset - but like I said, it was a good price. Anyway, I began by telling my old base unit to de-register handset #2 (the failed unit). However, I then found that I could not register the "new" handset with my old base unit because it was already registered to the "new" base unit. So, I first had to apply power to the "new" base unit and de-register the handsets. Then, I placed one of the "new" handsets onto my old base unit, and it said "Handset Registering ..." and registered just fine. Just for the fun of it, I placed one of the other spare handsets into my old base unit. It said "Hanset Registering ..." but then it beeped and said "Registration Failed." This is because I already had 4 handsets registered to my base, and the base can not handle a fifth handset.
Feb 15, 2009 | Uniden DCT-748-4 Telephone
Can put in base id
Did you try this (from the i5801 manual) -
To register a handset to the base, follow these steps:
Step 1: If ENTER BASE ID is displayed on the handset, proceed to the next step; if not, press MENU on the handset, then press ▼ until REGISTER is highlighted; now press OK.
Step 2: Locate the 15-digit Base ID number by pressing, at the base: MENU, then press until DISPLAY BASE-ID is highlighted, then press OK.
Step 3: Carefully enter this number using the handset dialpad. If you make a mistake, press to backspace. When finished, press OK.
In a few moments, the handset will be assigned a number (1-6). This will be the lowest available number in the sequence not previously assigned to another system handset.
Step 4: Repeat the procedure for any other unregistered system handsets.
Reply back if you have success. The Base ID is not from the bottom of the base unit, but is something you get by following Step 2 above.
Feb 04, 2009 | Vtech i5807 (735078006394) Cordless...
TRU8885 in Australia Charger/Power Adapter Issues
try to re charge on base. phone contacts base and hand set may require cleaning. the charging light may have separate circuit and may not be in series so you may get false indicator. the 1000 ma is good current and should charge correctly.
Jul 21, 2008 | Uniden TRU8885-2 Cordless Phone
New Handset Won't Communicate with Base
What is the maker/model of your Phone..?
Jun 17, 2008 | Uniden CXAI5198 Corded Phone
VT 2461 Won't let me register new handset
jimmackey
were you ever able to register the additional handset? I have the same problem with 4 handsets, one broke and I bought 2 new vt2420 handsets. The unit wont register handset #3 (the one that broke). Would love to know if you were able to resolve the issue?
Oct 11, 2007 | Vtech VT 2461 Cordless Phone
How does one get the handsets to record the new speed dial numbers on the base phone?
I'm pretty sure the speed dial numbers are programmed on a per-phone basis. Most people would not want changes on one phone's speed dial to effect the other phones. I know registering the handsets will not make a difference. If the cordless phone is working, it's registered to the base. This is required so your neighbor cannot buy the same phone model and use your phone line. In the old days cordless phones were permanently linked to one base but now you can get extra handsets on many systems and "register" the phone to work on your base.
Jul 06, 2007 | Uniden DCT-7488-2HS Digital Phone
Phones (4) do not work
If you tried the registration process discribed in the book, it is possible that the base may have gotten zapped. Happened to me. Bought a new DCT 758 (cheap at Amazon.com) with only one extra handset and used two of the old handsets with it. It will only support the handset in the base and 3 others, so you can't use all of the old ones (save them for extras).
Jun 10, 2007 | Uniden DCT758-4 Phone
Panasonic KX-TG2740 Cordless Phone Logo
797 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
