Question about Dometic Rooftop RV Air Conditioner
Hi cool or high fan still not working the back unit is the same unit.
So I used the following parts from the rear unit one at a time and tried it each time with no luck (Yet.)There are three small tube looking electrical units that all are like the capacitor in the same place. I replaced all with identical ones one at a time no luck. then I replaced the fan motor with the identical one . No luck. Then I took out a box that has the main power to it and 4 colored wires and a thermostat wire and replaced it with identical one No luck then a small little black electrical diode looking thing and replaced it no luck.Has to be the Control board in house or compressor.Which one do you think?
Yes but the high fan and high cool fan does not come on to flow air anywhere except on low cool or low fan.This occurs with Generator on or shore power. Are you refering to a circuit board that is in the house inside the filter cover?
Posted on Jun 25, 2008
  • 848 Answers
It looks like a control problem with the thermostat or relay board (if you have a wall mounted thermostat). If the compressor is coming on, then you need to look into the airflow of the unit. Whether or not the compressor is coming on, you need to check the voltage. Like every appliance on board, the air conditioner needs adequate power to operate. If the voltage is 110 volts a.c. or below, the effectiveness of the unit will start to suffer. After verifying correct voltage, we need to look at how the air conditioner does it's job- it requires adequate air flow over both the inside (evaporator) and outside (condenser) coils. If the air filter is clogged refrigerant will not be able to pick up enough heat from the inside air, and if the condenser coils are blocked by leaves, it will not be able to give off enough heat to the outside air.
N'finity 170 bottleis dual bottle zone wine refrigerator. Unit will begin cycle when turn off and on. Gets down to set temp and will cycle correctly maybe 2 times and then temp will slowly rise. Unit will...
Hi, there are some little thermal switches, and or 2 fans that may not be working properly. In both cases they are not cooling the unit down enough for it to maintain the set temperature. This unit is pretty much low grade, high cost, JUNK. Your minor repair might cost in the $400.00 to $500.00 range, but shortly after the evaporator (part of the cooling system) will fail. That part is not available. It took me $350.00 repair call to find this out. Good luck, and enjoy it will you can. By the WineEnthusiast only offer to help will maybe be a $150.00 price break on a new and improved model
Jan 25, 2013 | Refrigerators
Front unit high cool and high fan not working
just replace the fan ..... its seems there is some voltage problem
Jun 25, 2008 | Dometic Rooftop RV Air Conditioner
My carrier ac unit does not cool, I read the previous posts but they are not relative. The fan does not come on at all when the knob is in fan position. Correction, the ac cools but is not COLD. it is the...
These units are known for not working too well even if the rear coil is the least bit stopped up. This is the first thing you need to check. Pull the unit out of the case, (unplugged) Peer through the rear fan blade and inspect the rear coil. The rear coil looks like a radiator. When it is plugged up with dirt, the unit will only work partially and will overheat quickly. The compressor may only work part of the time. If this is not the problem, you either have a compressor that has weak rotary veins (valves) or low on refigerant.
Cleaning the coil: The rear coil is screwed to a rear fan shroud. You can take these screws out and carefully pull the rear coil out enough to wash it out good with a water hose and sprayer. Be aware, there are two line of tubing connected to the coil . If you are too agressive pulling this coil out of the shroud you can break these copper lines or kink them causing all kinds of problems. So, be careful and take your time. Also, make sure you don't have a real high pressure coming out of the sprayer so that you won't bend the aluminum fins. Hope this finds your problem
Jun 19, 2011 | Heating & Cooling
Fuses panel described in English
Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
Mar 07, 2011 | 1995 Kia Sephia
Freezer is very cold refrigerator is not cold as it should be
Check your temperature control (Thermostat) settings. If it is not on high/max cool then set it just less than the maximum. If it still does not cool then I am afraid the problem is of less cooling gas. You have to ask a technician to check and refill.
Feb 23, 2011 | Kenmore 74209 Top Freezer Refrigerator
Have a stoves 720 es main oven fan does not stay on to cool oven after switch off> also the oven will not trun back on when it is still hot or warm ? will
First things first. There are two fans. One in the bottom oven and one to provide background cooling. The background cooling fan turns on when anything is turned on. (Fan oven/top oven/grill). Just operate the top oven for a moment and this should cause the cooling fan to operate. There is a printed circuit board that controls the cooling fan and for how long the fan should stay on once everything has been turned off. (About 7 mins). If this fan is not running then the fan/motor could be faulty, or the circuit board or the resistor on the fan terminal block. The reason the oven will not turn back on is that the residual heat in the oven unit as a whole against the fan oven, is probably too high which causes the overheat device to operate.
You will have to take the oven out of the kitchen carcass, take the top and rear panels off and get an electrician to test and found out which item is not working/failed. Try espares for parts.
Jan 24, 2011 | Stoves 720EF Electric Double Oven
With the Dometic 3106995.032 thermostat fan switch set to "auto" the fan in the overhead A/C unit comes on (when system is set to "Furnace") as the temperature control is raised but the furnace doen't kick...
Hi, the wiring terminations are near consistent with a 24 volt ac furnace and I will tell you how a 24 volt stat is terminated. RC= 24 volts jumped to RH for red wire only. This would be for a central system with air and heat. W=white for heat, G= Green for Fan, and Y = yellow for cooling. I do believe it is wired correctly for your application. Please verify your units model and serial number and give me a clue as to what is taking place, and did you change the thermostat or make a part change?
A/C, & Heating Contractor.
Oct 19, 2010 | Heating & Cooling
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
When we turn the AC on, after a couple of minutes we hear a hum which lasts about a 1.5 minutes then shuts off. No fan air movement or cooling detected. The unit is 5 years old. We RARELY use it and when...
Go up on roof and using a stick or similar, poke it through the air holes in side & try to turn the fan blade at rear of the air conditioner. Make sure it's off at the time. Try to get 2 or 3 complete revolutions of the fan blades, then try turning it on fan only first,and let it run on fan for a few minutes, then switch to cool. If worse comes to worse and you can't get blades to turn, remove cover on roof (watch for wasps & bees) and spin fan blades a few times by hand, step back & have someone try fan only. If that works, then try cool. Sometimes they get a dead spot from sitting, and that will get it going again, 90% of the time. Let me know how it goes.
Jul 27, 2009 | Dometic Rooftop RV Air Conditioner
High cool and low cool not working
Pls check the following....
1) Fix the wire connector to Reversing vale
2) Check the Capacitor if this a low capacitance or (open) not function using Multi-tester.
3) Check the Selector switch if this is not function using Multi-tester . or check the PCB Board (if electronic your units) replaced the Board.
If not yet,go to the nearest repairman to repair that units.
Thank you,have a nice day.
Jan 25, 2008 | Amana PTC093B50AJ Electric Heat Air...
Dometic Rooftop RV Air Conditioner Logo
60 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
