Opening the dell 1707FP monitor - Computers & Internet
  • 3 more comments
  • mundane Jul 11, 2008
    I also need some info for opening up the dell 1707fp lcd. The problem being the power button is not working. I am not sure how I can access the button without opening the display
  • Anonymous Nov 03, 2008
    Power button seems to be stuck in the 1707FP, i cant start the dam monitor.......
  • Anonymous Apr 09, 2009
    Power button stuck on Dell 1707fp.
  • 159654
    159654 Jan 27, 2014
    tnx a lot fried up my monitor
  • 159654
    159654 Jan 27, 2014
  • 204 Answers
To open the case, do the following:
1. Remove the base from the back of the monitor by pressing the large black button on the back.
2. Remove the 4 large black screws located under the plate you removed in step 1.
3. Along the left side, towards the top of the monitor, locate the seam that divides the front from the back of the monitor. This is located along the left side and is about 1/16" back from the front of the monitor.
4. Using a flat blade screwdriver with approx a 1/4" wide blade, work the screwdriver into the left side seam, almost to the top of the seam. Your screwdriver should be going into the crack between two pieces of black plastic.
5. Gently turn the screwdriver left and right until you feel the front separate from the back.
6. Once you have a "hole" to start working from, gently pry the rear cover away from the front bezel. Make sure that the bottom right corner (closest to the power and adjustment buttons) is the last part of the front that you attempt to pry apart. Be extremely careful in this area, as the buttons are part of a small circuit board attached to the front bezel. While it seems like front bezel is the piece to remove, actually you want to remove the back case first. Pulling the front bezel too far away from the LCD screen itself can damage the flex circuit. Once you remove the back cover, you should be able to see the red and white flex circuit that goes to the front panel circuit board.
7. Gently fold the bezel away from the LCD screen, keeping the bottom edge of the bezel close to the screen. Again, use caution not to damage the flex.
8. Once this is done you should be able to see a green circuit board with 5 very small phillips head screws. Remove the screws and find a safe place for them. Once this board is removed you should be able to see the cracked button. In my case I just removed the pieces of the button and powered on the monitor using a small q-tip. Once reassembled, the actual button is inside the hole, but off to the left. The two contacts that you see directly behind where the button used to be are LEDs to indicate the power is on.
NOTE: In place of a q-tip, you can use any small, non-metallic, not sharp object. A pointy pencil eraser might work well too.
Reassembly is the reverse of disassembly. Hope this helps!
Posted on Feb 05, 2010
  • 4 Answers
I have some pics of the disassembled monitor. You can find them on www.pchuisdokter.be/1707fpo.html
Posted on Jul 27, 2010
  • 144 Answers
Check on Eserviceinfo.com. You can easily find a similar dell disassembly guide..
Posted on Jun 25, 2008
3 Suggested Answers
ajx13
  • 110 Answers
SOURCE: Can't power on my DELL 1707FP monitor
Try a different wall outlet. If no go swap the monitor and tower power cables. I still no joy disconnect the power cord from the monitor, hold the power button for 10 seconds with the power cord disconnected. Try Plugin intu cable. If the screen is still dead check with dell tech support if the monitor has a warranty active on it. If the warranty is out get the monitor checked at a local computer shop.
Posted on Aug 08, 2009
vittala
  • 318 Answers
SOURCE: how can i open my
using a screw driver
Posted on Jun 22, 2011
How to fix my Dell 1707fp monitor screen goes black after a few seconds when turn power on?
could be what they call the inverter and that is behind the screen at the bottom.
Nov 03, 2016 | Dell Computers & Internet
How to open dell lcd monitor case 1707FP c
I made a video of repairing my E178FBb and I show how to take it apart. I assume it comes apart the same as yours.
May 04, 2014 | Dell Computers & Internet
It is a Dell monitor, Model 1707FP. The screen went black and the power button is blinking. It does not make a difference whether I disconnect the video cable or connect it to another computer. What are...
http://s807.photobucket.com/albums/yy352/budm/Dell%201707FP%20Rev%20A01/
Check for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
Aug 12, 2010 | Dell UltraSharp 1707FP 17" LCD Monitor
On off switch on 1707fp moniter not working . I need a new switch. Where can I get one/
Try mouser electronics. You shouldn't have any trouble finding a replacement. Be careful if you open up the monitor though. There are parts in there that can electrocute you even after it's been unplugged.
Dec 07, 2009 | GPS
Power button damange ,
I used two thin putty knives this morning to open the monitor case. First, unscrew the four screws at the back. Then insert a putty knife into the small crack between the front bezel and the monitor shell. Carefully work you way around and wiggle the putty knives. Note that the front buttons are attached to the thin black edge at the front, and there's a thin cable at the bottom. Don't damage that. You can take off the back shell though.
Sep 09, 2009 | Dell UltraSharp 1707FP Monitor
Aug 08, 2009 | Apple Power Mac G5
Computers & Internet Logo
6,250 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
