Question about Bosch Axxis WTA 3510 Electric Dryer
Service Manual I would like to buy a copy of the Bosch Axxis WTA 3510 Electric Dryer SERVICE manual (not operating or user manual). Can you help me?>
    Brigadier General:
  • 6,966 Answers
Based likewise on your Premium Problem/Post here, I tried looking for a service manual but only found a possible source of the wiring diagram, have you tried here. Unfortunately, you need to be a paid member to access the files to my understanding.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 26, 2008
    Genius:
  • 1,665 Answers
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jun 26, 2008
    This is a friendly reminder that as of Aug 1, 2005 only paid members will have full access to this site. Membership is $50 US per year and is only for Full Time Appliance or HVAC Techs.
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Where to buy and how to replace the thermal fuse?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 18, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis electric dryer, 3 years old, dryer drum won't turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis dryer - lint filter indicator lights up
Make sure the exhaust vent duct is clean all the way to the outlet.
Nov 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer. I changed the fuse but it won't turn. Could it be the motor because I don't hear any sound?
there is a switch next to the belt tension arm behind the motor that needs to be reset push the switch needs to be pushed to the right andthis should get your unit running as long as you have power
Sep 16, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch axxis 3510 dryer doesn't dry clothes
well first check the Thermal area inside the unit, if you have an idea doing this, it could possibly easily for you to do the work.. on the thermal area check for any burn fuse or any faulty parts relating or was connected on the thermal area.
Jun 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
866 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
