P-133 6 CD player in my Subaru...won't eject or play
  • clapella Oct 13, 2008
    I am having the same problem as the above poster. Please point me in the direction of some repair/remove service or website if any.
  • Anonymous Mar 30, 2009
    Same problem in our 2005 Subaru Outback - player has 6 CDs in it and will not eject or play
  • 2071 Answers
SOURCE: the cd player in my
Need to clean and resoldering works.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click fixya.It is the only way i get paid for my work...
Good luck:
Posted on Jul 25, 2008
SOURCE: 2005 dodge ram cd player won't eject cd
the dealer told me not to use burned cds to long in the cd player. the cds are a little thiker then a regular cd. i had to not use the cd player for a couple of days. once the cd cooled down it cam back out and i havent had a problem since. Solution dont let burned cds get to hot
Posted on Dec 04, 2008
  • 6784 Answers
SOURCE: 2003 silverado CD player
HI. you will need to replace the loading dock motor. once this replacement is done, you will have no problem loading and unloading your media. This repair will need to be initiated by Bose unfortunately. you will need to send it to Bose.
Posted on Jun 05, 2009
SOURCE: cd stuck in my in dash player in my car
recently had this problem, take two credit cards or id, and use them as tweezers to pull out cd(s). It works better, faster, and does little to none scratches on your cd(s).
Posted on Jun 09, 2009
  • 6784 Answers
SOURCE: cd won t eject from 2006 Ford Focus mp3 player Get
HI, either the deck assembly is jammed or, the load motor has failed. In this case, you will need to disassemble the entire set in order to retrieve this CD.
The actual loading deck(the part where the CD is located), is surrounded by a metal housing. the gear assembly is probably locked, due to this jam or failed load motor. This will also require a set of precision tools as well. if you find this a bit overwhelming, i suggest taking this unit to a local automotive audio shop. they can dissemble it and, retrieve the CD for a small price.
Posted on Jun 21, 2009
Blu ray player won't play or eject disc
If you want to eject the CD you need to look on the front of the Blu-Ray drive for a small hole, about the size of a pencil-lead. If you open a paper clip and insert it, it should pop the drive open for you.
Mar 06, 2013 | Televison & Video
JVC xl-fz258 won't open to eject cd, won't play
The basic problem is that the drive mechanism has failed. The problem with CD ejection can be caused by binding in the tray or a weakened ejection motor
Dec 02, 2012 | JVC XL-FZ258
Cd won't eject - reads "error"
you may have to remove cd player and have the cd removed .then maybe the unit may need to be may be of help.
Dec 02, 2012 | 2005 Mercury Grand Marquis
Cd player won't eject or play cd's in my jaguar xk8
The Cd loader mechanism is faulty. Replace it.
Jun 06, 2012 | NAD L40 CD Player
CD Player keeps ejecting the CD
Either Cd is problematic or lens inside of cd player is covered with dust. There is no way of properly cleaning it unless you remove the cd player out and disassemble.
You may try cd cleaner kits but ususally they cant help.
Nov 25, 2011 | Cars & Trucks
Turntable will power up, all the lights come on,reads the cd but does not play. unit has to be turned off then on to eject the disc ? (hope this helps) Any ideas?
One of the buttons has got stuck, so when you press the button you want to, its not getting the message to start / stop playing. This is also why the eject won't work. Either a new button, or replacement board would make it happen for you :)
Jun 24, 2011 | Pioneer CDJ-1000 CD Player
CD Changer is stuck
drop the faceplate, there should be a tiny hole you can push a paper clip in. push in a little bit and it should eject. good luck
Nov 30, 2008 | 2005 Subaru Outback
91 people viewed this question
