GoVedio duel deck VCR Model # GV3060x will not turn on. Fuse is good but change it out anyway but it did not cure my problem.
    Guru:
  • 1,894 Answers
The problem can be due to some other component on the power board. have u replaced the power board fully?
Posted on Jun 25, 2008
  • 1 more comment
  • dewan nafees ahmed Jun 25, 2008
    i think there is no problem in ur VCR .
    the problem is in the power circuit,.
    instead of changing the fuse alone u could have changed the power board fully.
    before changing the fuse u must have concluded if the fuse was faulty.
    u could have done it by simply measuring the resistance between its terminals.
    see this link for ur VCR set up.
    again change the whole power section
    or
    find which part of the power circuit is faulty and then replace that alone.
    this wil fix u easily.
    hope it helps.
    thank you
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
Before I cleaned the head, no pic.. after cleaning the head, no pic.. what do I do?
If you can hear the sound then cleaning the head sometimes works. Unfortunately no amount of cleaning will cure a faulty VCR head
By the way you posted this in the cassette and Reel to Reel tape section not the VCR section so it took me longer to see this.
Dec 07, 2015 | Audio Players & Recorders
VCR will not turn on
any led indicators that the unit got a power..?
Jun 25, 2008 | Televison & Video
My Panasonic NV-HD660 VCR is not unloading/ejecting a video cassette, in fact turns off itself and shows error message HO2, please help!
Yes the most likely cause is the mode switch, you can spray it with Servisol Video 40 or replace it. But you will need the service manual for that. The good news I think your model uses a K-Deck, and there is plenty on-line about the Panasonic K-Deck.
Dec 02, 2010 | Panasonic NV-HD635AM VCR
My tape is stuck inside and i want to eject
Locate any screws that hold the top in place. carefully slide the top off. find the loading motor. it should have a worm gear on it. turn the gear and after a while the tape should come out. is this only in one vcr in the duel deck? please reply if you can fix it. if that did not work, just let me know. good luck!
Jul 09, 2010 | Rio Go Video DDV9050 Dual Deck VCR
Unevan cut duel blades adjust deck
If the mower has been cutting fine in the past, and you do not see anything loose on the deck between the deck and the chassis. I would check the air pressure in each tire.
HTH
Good Day.
Oct 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
VCR runs 10-15 sec. shuts off.
most vcr decks are clones of other decks .find out what deck is fitted in that model ...might find that a easier way to trace a service manual. check R.S components parts ..i'm sure they have a section on vcr decks and a large parts and service sections with pictures to help you identify your deck. ps if you have never done this sort of thing before i would think hard on whats involved it can be very time consuming and awkward to do....deck timing can be a real pain to get right. i would start with the easy things to change first like the pinch roller.anyway hope this helps a bit ..farr64
Apr 27, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Worn out belts
Thanks anyway but I was able to find the drive belts I needed.
Jan 09, 2009 | Rio Go Video GV6060 Dual Deck VCR
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
