Question about Fujitsu FPCRC05 Remote Control
Ductless Air Heat remote
I need help. I have a dual zone Fujitsu ductless system. The remote says AR-RY7 on it. Is it possible to obtain another manual on how to use it properly? Thanks. Crescent 818-404-9536
  • 2 more comments
  • Milkam Sep 28, 2008
    How can we switch from Farenheit. to Celsius  with this remote AR-RY7. I can see on the led display that this can be done. But no way of doing it ?
    Thanks to all helper
    milkam@rentgamecanada.com
  • Pascal99 Oct 02, 2008
    I have the same remote but the only jumper that I have is next to the battery that is J4. I remove it and the remote still show me the temperature in Farenheit intead to Celsius.
    I dont know what to do.
    Pascal
  • Anonymous Mar 12, 2009
    no instruction manual
  • Anonymous May 21, 2009
    Same problem! Someone had tested the solution. Remove the J5 jumper is it working?
The solution is to remove Jumper J5 at the top of the circuit board. For that you will need to open the remote by removing the 3 screws underneath, split open the case and then remove the 4 srews inside. Removing such a small jumper requires precision and you should use a magnifier to focus. You can scratch it off gently using a flat blade screedriver. Test before reassembling. I have succesfully converted both of my remote to Celsius. Fujitsu is guilty for that, the metric system is around for over 40 years everywhere.
Posted on Jun 06, 2010
I have the same remote(and the same issue), for a Fujitsu ASU9RMLQ system. I just found the link to the manual for my system, it has some instructions on how to use this remote:
http://www.fujitsugeneral.com/PDF_06/OperationManual/(OM)AOU24-36RML.pdf
Posted on Jul 29, 2008
The remote control model number for the 12RLQ system is AR-RY7. To convert remote control model number AR-RY7 from Fahrenheit to Celsius, please remove J5. Do not remove R4.
Posted on Jun 11, 2009
Solution #1 is almost right.
For the AR-RY7 remote, remove jumper J5 not J4.
Posted on Nov 23, 2008
For those who would like to get the info.
Here is the instruction to switch from Farenheit to celsius with this remote:
OK. The process is pretty easy. You will need a pen size Philips head screwdriver and a pair of tweezers.
First: Remove (3) screws from the backside casing of remote
Then: Open the casing by separating the top from the bottom.
Then: Remove (4) screws around the circuit board
Then: Lift board and carefully remove the display screen
Then: On the printed side of circuit board locate J4
Then: With your tweezers remove the J4 jumper. (Be sure it is totally removed, with no connection)
Lastly: Reassemble your remote.
Following these instructions will convert your remote from Fahrenheit to Celsius.
This information was posted to me from Fujitsu Representative.
See ya
Milkam
Posted on Sep 29, 2008
Unit trips the beaker as soon as you turn power on
When the breaker trips immediately, you usually have a direct short in the unit. It's best to have a qualified technician check it out.
Mar 23, 2016 | Fujitsu AOU48RLXFZ HFI Multi Zone Ductless...
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
Room temperature senor not working
Hi Karl,
I hope the following links is helpful to you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 24, 2015 | Fujitsu ASU30CLX1 Single Zone Wall...
How do I use the heat on my Fujitsu ASU15RLS2?
there is an outdoor unit and is probably low on Freon and not working. it probably needs service. if the indoor unit come on, then the outdoor unit has power but may be low on Freon.
Nov 16, 2014 | Fujitsu ASU15RLS2 Single Zone Wall...
I am not able to get the unit to change from air conditioning to heat
Unfortunately these units are not user fixable , beyond checking for power and checking battery in remote. You would need to call a pro who is able to get service information and has special digital logic meters to diagnose and repair .
Oct 04, 2014 | Mitsubishi MXZ-2B20NA-1 Mr. Slim Dual Zone...
Removing filter
Go to the following website: http://www.younits.com/asu9rls2-single-zone-wall-ductless-indoor-unit-handler-9000-p-11467.html
Click on the "Literature" button, and then on "User Information Manual" when it is displayed. Your answer is on page EN-13.
Nov 11, 2013 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
My samsung ductless air conditioners work great except the remote only works for one out of the three. amd yes there are new batteries in the remote. how do i program the remote for the other units?
Ductless? I assume you mean you have separate split systems? Samsung, like al lot of Manufacturers obtain units from different suppliers. The other 2 machines may be different models from different factories. The remotes for these wont work on machines from a different place, even though the brands are the same.
Sep 07, 2013 | Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
I have a remote control unit Model : AR-RY7 fujitsu for a ductless airconditioner unit without a manual. I need to know how to program it.
Jane,if you are still interested: Go to www.fujitsugeneral.com, click consumer, click service and parts, click manuals. Enter the model number of your indoor unit = small numbers on right hand side (e.g.,asu12rmlq and put plenty of paper in your printer. I had 19 sheets. Lots of luck. Bob
Apr 02, 2010 | Fujitsu FPCRC05 Remote Control
My GE ductless system is not heating properly and trips breaker
Call them yourself. Let them know your compressor is tripping your breakers. Also, ask how to obtain parts for your system. It's rediculous an hvac tech cannot get advise from ge.
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Fujitsu FPCRC05 Remote Control Logo
2,429 people viewed this question
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
