Question about Candy FP855 Electric Single Oven
Candy oven heres a tricky one when you select fan oven the grill comes on selector switch seems ok cant seem to figure it
  • Anonymous Mar 21, 2014
    I need to change selector switch but cant get to it!
  • Anonymous Mar 30, 2014
    single oven with gas grill. grill comes on but not oven what should I do it is new
You either have wire,s crossed or you need a new selector switch
Posted on Nov 13, 2008
Oven not heating but grill still working
Call an electrician and ask them to check your 'Bake' elements.
If the elements are working, then check the oven function selector switch to make sure all of the contacts are working.
Apr 15, 2014 | Candy Ovens
CANDY F 254
Possibly the fan in the oven has developed a fault. Get an electrician to come and test the fan.
The worker should do tests on the oven to make sure everything is safe to use once any repairs are done.
Mar 16, 2014 | Candy Ovens
My grill doesnt seem to be working,the oven seems to be ok making all the noise and stuff but the grills just not playing ball! nany help would be appreciated!
More than likely the grill element has failed, if the element light comes on, then I would go for the element.
If no light, then probably the grill switch is faulty.
Nov 14, 2010 | Zanussi ZBF360 Electric Single Oven
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Baumatic BT187ss Oven All working EXCEPT fan assisted cooking
I have a similar problem with my Zanussi and discovered there is a seperate element arounfd the fan wihich I think may be burnt out. Could be a similar fault have you investigated behind the panels in side the oven?
Mar 08, 2009 | Baumatic B180 Electric Single Oven
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
Cleaning above the grill element
I would not advise you to remove the element unless you feel competent to do so.
Best thing to do is to put the grill full on and let all the fat and grease burn itself off.
you will not hurt anything by doing this.
Make sure you have the griil door open and your house door.
Plz rate my solution.
thanks.
Dec 18, 2008 | Candy FP855 Electric Single Oven
How do I switch off child lock from my neff oven 1641
So, you should have a "-s-" being displayed if you have the child lock on.
The switch for selecting the oven mode( oven, fan oven, grill etc)
-from its off position, turn it one click left so the light comes on, and then click it back to off. Do this three times in quick succession. The "-s-" should now have disappeared and you can use your oven again.
Regards,
Steve.
Sep 09, 2008 | Neff B1641 Single circotherm super...
Candy FP855 Electric Single Oven Logo
517 people viewed this question
Top Candy Ovens Experts
ashburton
ray gallant
Gaark
Are you a Candy Oven Expert? Answer questions, earn points and help others
