Question about Cameras
My Optio S4 has it`s ccd screen totally filled by vertical striations when it is switched on. This happens on most but not all times. They are of different widths and various shades of black/grey. Can you diagonose the problem?
  • 1 more comment
  • petermaria Jun 29, 2008
    Not clear what you mean. Change camera or change ccd? If the latter where can I purchase a replacement from and is it simple to replace it myself?
  • petermaria Jun 30, 2008
    Have tried resetting but problem still remains. Because the problem is intermittent I suspect it is some kind of connection problem. Is this likely?
  • petermaria Jul 02, 2008
    None of the experts diagnosed the problem. I am no wiser than when I started with my enquiry. As I live in the UK the 2 repairers suggested are not practical.
    Genius:
  • 2,035 Answers
This could the problem with the screen as the time of useage they tend wear here may be lose connection or broken lead in the connection you need to get it serviced from local service center ..
Posted on Jun 30, 2008
    Genius:
  • 1,011 Answers
Dear Sir,
This problem is fixed only with service centre. Contact service centre immediately. For more information below.....
PENTAX has determined that a limited number of units are affected by this condition.
However, the situation may accelerate when units are exposed to high temperatures and
humidity.
While only a limited number of cameras are affected by this advisory, if your camera
is experiencing the above symptoms, PENTAX would like to inspect it for service.
If your camera is affected by this malfunction, PENTAX will repair it without charge even
if the manufactures one-year warranty has expired. This will not apply if the camera has
any other than the above-mentioned symptoms. If you have any questions about this
problem, please contact an authorized PENTAX Service Center. To obtain complimentary
service for cameras affected by this advisory, please download and print the service return
form and follow the instructions on the form.
Pentax USA have published a brief note on their Customer Care & Support homepage which refers customers to a separate PDF file for further information. This document pledges repair of the problem free of charge, regardless of warranty status, as long as the camera doesn't have other symptoms not described as part of the problem.
This PDF document in turn refers customers to a separate PDF form which must be filled in, and includes instructions on how to return a camera for service. The return address from the form is:
PENTAX Service Department
12000 Zuni Street – Suite 100B
Westminster CO 80234
We couldn't find any details regarding the duration of the free repair offer, nor of serial numbers affected. We suggest you simply contact Pentax for clarification of these points.
http://www.pentaximaging.com/customer_care/pentax_service/index.jsp
http://www.pentaximaging.com/files/scms_docs/service/return_ship_label_xmas.pdf
http://www.pentaximaging.com/files/scms_docs//CCD_Service_Information.pdf
Thanks
Good Luck
"Don't forget to rate the solution"
Posted on Jun 29, 2008
  • 13,433 Answers
I would recommend sending this camera in for service.
Here are a few places I can direct you to
http://www.advancecamera.com/repair/
http://www.precisioncamera.com/
or you can contact the maker for their own service details.
    Genius:
  • 1,142 Answers
Reset the device first then we can do something else.
    Master:
  • 497 Answers
Have u tried an upgrade?
  • Yaz  S
    Yaz S Jun 29, 2008
    u cud get a replacement LCD for $40 f it is second hand. A new one from PENTAX Part Number 76650-0500 Tel 1 800 877 0155 Is just under $60 plus $8 shipping in the USA but is currently out of stock. There is also a San Diego company with limited stock (5) that wants about $70.
    Removal of the LCD is relatively straight forward. First remove the battery and the card. Then unscrew some very minute philips screws and carfully remove the back cover. Separate the two halves of the cover with a thumbnail to unhook a snap connection after the screws have been removed.
    It's best not to remove the front cover so as to avoid damage or contamination of unrelated areas.
    To remove the LCD look for the retaining snaps and gently pry the left side ( camera facing forward and upright) back and lift the
    left side of LCD up and unhook the right side.
    The LCD will now still be attached by the multi wire strap and a minute two wire connector. Using tweezers on the plug and not the wires gently disconnect the two wire connector. The multi wire strap with about 25 miniscule gold connectors is held down on the mating contacts with a clear sticky tape. I was able to pull mine loose before I saw the sticky tape.
    To reinstall the replacement LCD a very good magnification of the 25 or so contacts may be required to correctly line up all the mating contacts on the back of the camera as there is no apparent mechanical means to correctly align this.
    There is no soldering required or practical at his connection.
    Use some clear sticky tape to hold it in position.After reconnecting the 2 wire plug the right way up and when the LCD is folded over back into position and snapped down into to the retension snaps,this should also apply gentle presure to the 25 pin connector. Adding a very thin layer of non conductive material over the 25 pin connector before snapping the LCD back might be helpfull in the longterm retension but too much compression will may fail the new LCD. ( Well that is what I'm going to do when I get my LCD) ( I may also put the battery and card back in and switch it on before replacing the rear cover taking care not to get an electrical shock through some accidental discharge, so don't do as I say unless you know what you are doing)
    Re assembling the rest should be straight forward. Then test the result.
    Add in an extra layer of clear plastic over the exterior cover of the LCD to better protect it. It is also advisable to have a hard case or reinforce a small soft case with a used credit card to protect the LCD, so as not to have to repeat this again.
    in my opinion it wud be better of if you contact ur authorized dealer.
  • Yaz  S
    Yaz S Jun 29, 2008
    hope this wrks
    All the best
    tc
    Guru:
  • 1,894 Answers
This is the problem with your CCD sir.
it needs a service
  • 2 more comments
  • dewan nafees ahmed Jun 29, 2008
    take it to authorized service center and get it fixed. it wont take you more than 200$ i think sir.
    please take it to the authorized service center.
    it is not CCD screen sir. it is LCD screen.
    also this problem happens when there is a problem with the capturing surface sir.
    this can be fixed by replacing your CCDs.
    so go ahead.
    hope it helps.
    dont forget to accept MY solution if you FIX by it.
    feel free for asking any doubts you have.
    thank you for your cooperation.
    good luck for getting fixed soon
    have a great day
    no chance that it can be done by unexperienced persons sir.
    it needs great expertise to fix this thing.
    you must take it to service center only.
    even if you purchased it, its very difficult to replace this part.
    it must be done in a factory environment only.
    please don't damage your camera by trying to repair it by yourself. its my kind advice.
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Screen shows blurry vertical lines instead of image
It is failure of ccd imager chip in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Red vertical lines and horizontal flashing lines on viewing screen plus fuzzy picture.
Its bad ccd imager problem in your Sony DSC-T1 camera and Sony will repair it free of cost.
May 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Pentax Optio s50 screen problem
If no error code on the LCD screen, then you have either very weak batteries or a bad CCD problem/malfunction. One way to test the batteries is plug in your AC/DC source and try to turn on your camera again and try taking some pictures. Also make sure you have a memory card present in the camera. If it works, then it was the batteries. If it still doesn't work, then its the CCD. Time for repair.
Dec 21, 2008 | Pentax Optio S50 Digital Camera
A90 error Optio S4
Gerrit
So is jou probleem uitgesorteer ?
Apr 17, 2008 | Pentax Optio S Digital Camera
PENTAX OPTIO A30 BROKEN LCD
I've seen LCDs forA30 are sold via eBay.
In youtube there's a video of replacing the LCD in other Optio model.
I have the problem and I'm going to try it by myself. I'll let you know if it worked.
Jan 08, 2008 | Pentax Optio A30 Digital Camera
Pentax Optio
Normally there are two reasons for the given problem. 1). Bad or defective CCD. and/or 2). shutter not working. in the first case the only solution is the replacement of the CCD. and in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Sep 13, 2006 | Pentax Optio S Digital Camera
Optio s4 - help needed
You are probably in play mode and not in camera mode. Switch the camera back to camera mode (move the witch so its in the camera position- you will see a small camera icon) in order to take pictures.
Sep 08, 2005 | Pentax Optio S4 Digital Camera
S4 LCd problem
my screen wont let me do anything the screen comes up as card locked
Cameras Logo
52 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
