My monitor comes on for a second when turning on my pc but then goes off. if i turn it off from the monitor power button and then turn it on, it will again flash on for a second and then go off???? I can keep turning the monitor off and on and see the screen for a second, but then it goes off.
what can i do?
Hello can someone help me?? the problem is when i turn the monitor on i just can see shine white i can do anything my monitor is del E197FPf lcd thanks a lot
SOURCE: LCD monitor no display - flashing power button
hello, my best guess is that the refresh rate is set for a crt monitor. hook your old one back up, if you can. and change it to 60 hertz or 70hertz. go 2 display properties then settings then advanced; then monitor. set the refresh rate as i said and turn off the computer, hook the new one back, and you should be good to go. good luck! and please rate this solution. if you need further assistance, reply
SOURCE: E153FP Monitor screen goes black light is green
I agree. The capacitors have popped. I found a local TV repair shop and the guy put new capacitors on the board for me for $5, so it's an easy fix. The monitor is difficult to get apart, but if you'll look carefully you can see small slots in the plastic, mine were on the bottom side, then insert a very tiny flat screwdriver carefully seperating the cover, using a slightly larger screwdriver in the gap, twist gently until the case pops open. Remember to take all the screws out of the exterior, and not to push the screwdriver in too far and scratch the screen. Good Luck.
SOURCE: Dell E172FPb 17" LCD Monitor Problem
C2? 1000uF 50vdc Electrolytic, worked for me, identical problem.
SOURCE: Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce
eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
SOURCE: blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
hey man, i have same problem as you, with your flat screen monitor, flashes 1 second with power buttong goigon off and on, if you have solved this soloution can you tell me how to email me.
thanks
