Question about Casablanca Fan 3245T Ceiling
Our casablanca ceiling fan has power going to the fan and the remote works but the fan does not nor does the light
  • 1 more comment
  • marmie2355 Jul 16, 2008
    Our Casablanca fan has worked for years but today we have the same problem.
    The remote has new batteries, the circuit breaker is fine but we can't get the fan or light to turn on.
    I wonder if a rodent has not chewed on the wires in the attic or if the high humidity this summer in eastern Ontario may have something to do with it.
    What can I do to try to solve this problem myself?
  • ljaramillo13 Jan 18, 2009
    I have two Casablanca ceiling fans. I have power at the fan, but neither the fan or the light come on. The fans were at another house, I removed them and installed them at another house, and this is when they stopped working. There is 120V at the fan, What do you recommend I do?
  • Anonymous Mar 24, 2014
    w-62 remote not communicating with fan
    New Friend:
  • 45 Answers
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Posted on Feb 06, 2009
Shut off breaker for five minutes then turn back on. Within 20 seconds push the high then medium then low fan buttons. Wait 10 seconds and see if that resets the receiver. If not, find a new remote kit.
Posted on Jan 28, 2013
If you have power at the fan I would suspect you have a bad pc board.
Posted on Sep 22, 2008
5 Suggested Answers
  • 70 Answers
SOURCE: Casablance Ceiling Fan Trouble
itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
Posted on Jul 25, 2008
SOURCE: Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Posted on Aug 05, 2010
MN_Jack76
  • 45 Answers
SOURCE: i have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
Posted on Feb 09, 2011
seddy29732
  • 147 Answers
SOURCE: My Casablanca ceiling fan model
Hi, my name is Shaun. Welcome to FixYa. I have been an electrician for 6 years, and I have to say that your troubleshooting skills are impressive. Looks like you have covered all the bases. So, to answwer your question, the problem is most likely, yes, your reciever in the fan, unless the transmitter has been dropped or damaged in some way. Recievers rely on transitors to close the higher voltage circuits to turn on the lights and fan, and these tend to burn out occasionally. I believe you can buy wireless kits from Home Depot or Lowes that include both transmitter and reciever. In the meantime, you can rewire your fan and light to operate from the switch if you have pullchains or seperate switches for light/fan. If you do and you would like me to walk you through this process, reply to this answer. Hope this helps out. Have a good one!
Posted on May 09, 2011
How can I change from a remote control system ( which rarely works) to a wall control switch for my isotope 44 from casablanca
Casablanca may be able to supply instructions for alternate methods of wiring your fan for direct control vs. remote control.
Jul 28, 2014 | Casablanca Fans 44" Casablanca Isotope...
Fan working but light won't turn off from remote
Call Casablanca @ 1-800-715-0393. It could be a bad light kit ( which can be replaced) or bad receiver.
Jun 01, 2014 | Casablanca Fan 3245T Ceiling
I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
I have a Casablanca "trident"
Hello Duke,
Hope this helps.
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
Remote stopped working, fan and light do not
click the reset and turn off the fuse box and then turn on
Feb 15, 2010 | Casablanca Fan 3245T Ceiling
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
Fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Aug 07, 2008 | Casablanca Fan Televison & Video
Jul 16, 2008 | Casablanca Fan 3245T Ceiling
Casablanca Fan 3245T Ceiling Logo
1,100 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
