Question about Polaroid FLM-323B Television
SOUND OUTPUT I CONNECTED THE SOUND OUT TO AN AUX IN ON A STEREO RECEIVER. I CANNOT GET THE SOUND ON THE STEREO RECEIVER. THE STEREO RECEIVER IS SET FOR THE CORRECT INPUT?
Stick a headphone male chord into the headphone jack halfway. worked for me
Posted on Jul 26, 2008
How do I connect my TV (JVC model# EM28T) to my stereo receiver (Harmon Kardan model #HK3470).
U are connected properly - BUT it appears there is no output from your tv audio jacks to drive your HK amplifier. Ordinarily those outputs on a set are always hot but you might want to check your tv manual to see if there is a switch on them.
Dec 30, 2015 | RCA Audio Players & Recorders
Our turntable is not producing any sound even though we have changed the speakers
Be sure the audio-out leads are connected properly to the receiver. They usually will work ok connected to the aux. plugs. Be sure the selector on the front of receiver is set to aux as well. Check the cartridge output wires to insure they are connected to the cartridge ok. If you have the receiver powered up and have the proper settings on the front of the receiver, you should get a little static sound when plugging the audio output leads into their respective input jacks on the receiver.
Feb 21, 2015 | Audio Players & Recorders
How to conect my wiring tv cabale to my stereo component
For a simple stereo connection If you have a spare set of inputs (CD, AUX, video but NOT Phono/LP) on your receiver, preamp or whatever makes your speakers make noise that accept a pair of red/white RCA type inputs connect the OUTPUT of either your cable box, satellite receiver or TV audio Left & Right (red & white RCA jacks) to the INPUT of your receiver. If your cable or satellite receiver has a digital OUTPUT (either optical or coaxial) and your receiver has a like INPUT and 5.1 surround sound capability you can connect that to give you a surround sound mix.
Feb 12, 2013 | Televison & Video
I have a pioneer sx-2300 i bought at a garage sale i can get the radio to work but i cant figure out how to get the tv to play through the speakers connected to the receiver i have connected the tv and the...
Your RCAs should go from the audio out on the TV to the Aux input on the receiver. put the source selector on the Receiver on aux. that should give you sound. Go to the TV menu and verify that it is set to variable output in the audio settings.
Good Luck!
Sep 12, 2011 | Pioneer Audio Players & Recorders
I have a Harmon Kardon HK 3370 Stereo Receiver and a Samsung LCD LE40C530F1W. When I connect the stereo Aux jack to the LCD Audio jacks ( red and white rf cables ) I get no sound out via the receiver.
Obviously make sure your stereo mode selector is set to AUX and the volume on the stereo is turned up at least a little when you test it.
If you still have no luck then try increasing the volume on the TV as well. You may have it set so that the level of the audio signal leaving the rear output connectors on the TV varies with the TV volume. That way if your TV volume was turned down or muted when you tested it, then you would not hear anything coming through your stereo.
There should be a setting in the AUDIO OPTIONS menu of your TV where you can switch between a VARIABLE AUDIO OUTPUT and a FIXED AUDIO OUTPUT level.
With the FIXED audio output level, you control the volume of the TV audio coming through the stereo speakers with the stereo remote only.
Otherwise it should work.
Good luck.
Jul 16, 2011 | Harman Kardon HK 3370 Receiver
How do I get the stereo sound through my tv so when I am watching my tv stations I get stereo?
Hi,your TV automatically switches to Stereo mode and a pilot lamp comes on most TV sets.
If you want to listen your TV on your Stereo system thru your receiver, you need to connect "Audio Output " RCA jacks of your TV to "AUX input " or "Any input" of your receiver ( except Phone ) than just switch to respective mode corresponding your RCA connection..
There you go..Your TV sound is on the Receiver..
Take care and pls remember to rate me..
Thanks
Jun 19, 2011 | Philips Audio Players & Recorders
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
Stereo hook up to my 51h84c toshiba
YES YOU CAN DO IT BY YOURSELF. IF YOU HAVE A STEREO, IT SHOULD HAVE AUX INPUT...YOU WILL NEED AUDIO CABLES, RED AND WHITE...CHECK AT THE BACK OF YOUR TV, WHICH SAYS...AUDIO OUT..PLUG THAT TWO CABLES COLOUR CODE MODE...AND THIS END YOUR CABLE GOES IN YOUR STEREO AUX INPUT...ON YOUR STEREO SWITCH TO AUX AND SAME TIME ON YOUR TV....SO YOU WILL BE ABLE TO HEAR SOUND
Oct 14, 2009 | Toshiba 51H84 51" Rear Projection...
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Polaroid FLM-323B Television Logo
61 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
