my 2007 ford fusion V-6 kept corroding the termianl as well, the battery had a leak around the terminal they replaced the battery at the dealer and I have not had an issue since.my 2007 ford fusion V-6 kept corroding the termianl as well, the battery had a leak around the terminal they replaced the battery at the dealer and I have not had an issue since.
You can't post conmments that contain an email address.
? 2:01
www.youtube.com/watch?v=H0BhHWT2cyY
Sep 16, 2014 - Uploaded by mlmunoz21
Ford fusion won't start ... Published on Sep 16, 2014 .... 2004-2008 F150 Died Out No Crank Theft Light ...
? 0:32
www.youtube.com/watch?v=lmH7R6Ebmyc
Jan 9, 2015 - Uploaded by Nicholas A.
Any ideas why it won't start? 2007 ford Fusion awd 6 cylinder. ... And P1260 2007 Ford Fusion - Theft ...
Ford Fusion 2007 user manual page 245 under FUEL FILTER" section. It states "Your vehicle is equipped with a lifetime fuel filter that is integrated with the fuel tank. Regular maintenance of replacement is not needed.
2008 Ford Fusion Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red Car Radio Accessory Switched 12v+ Wire: Green Car Radio Ground Wire: Black/Blue Car Stereo Antenna Trigger Wire: Purple/Black Left Front Speaker Positive Wire (+): White Left Front Speaker Negative Wire (-): White/Brown Right Front Speaker Positive Wire (+): White/Purple Right Front Speaker Negative Wire (-): White/Orange Left Rear Speaker Positive Wire (+): Brown/Green Left Rear Speaker Negative Wire (-): Brown/Yellow Right Rear Speaker Positive Wire (+): Brown/White Right Rear Speaker Negative Wire (-): Brown/Blue
the battery is most likely low or the cables to the battery have become corroded. try a jump and clean cables. symtoms of low battery/corroded cables are a rapid click/buzz sound when turning key to start
Most new vehicles seem to do this, just take the positive teminal off the battery clean it with a wire brush and put back on making sure its tight. If the battery is getting older replace it. If this doesn't work hook up a battery charger and try taking the key back out.
