Question about Dryers
I have an old dryer that has a 4' exhaust pipe, the hose that i need to connect to it is also 4' and won`t go over the pipe. How can i fix this?
    Problem Solver:
  • 5 Answers
Usually, the exhaust duct is crimped, which makes it slightly smaller in diameter. If not, you can get a crimper at Home Depot. Crimp it all the way around, slide on your extension, and fasten securely. You should contact your local fire house to see about dryer exhaust material regulations. They could save a life by preventing mistakes or assumptions.
Posted on Jun 25, 2008
My husband and I are trying to get to our thermostat to change in my 2002 rendezvous, but there is a metal pipe in the way that we can't figure out how to remove. just behind the pipe, is a metal plate...
Hello vocalviixen,
The pipe that you referred to is the exhaust crossover pipe. Below I've included removal and installation instructions.
Also, the procedure for bleeding the coolant system is critical; if you need those instructions please post the question.
REMOVAL PROCEDURE
1. Disconnect the battery ground (negative) cable.
2. Remove the throttle body air inlet duct.
3. Drain the coolant from the cooling system.
4. Remove the inlet radiator hose from the engine.
5. Remove the thermostat bypass pipe.
6. Remove the exhaust crossover heat shield bolts.
7. Remove the exhaust crossover heat shield.
8. Remove the exhaust crossover pipe studs/nuts.
9. Remove the exhaust crossover pipe.
INSTALLATION PROCEDURE
1. Install the exhaust crossover pipe.
2. Install the exhaust crossover pipe studs/nuts.
3. Tighten the exhaust crossover pipe studs/nuts to 18 lb ft.
4. Install the exhaust crossover heat shield.
5. Install the exhaust crossover heat shield bolts.
6. Tighten the exhaust crossover heat shield bolts to 89 lb in.
7. Install the thermostat bypass pipe.
8. Install the inlet radiator hose to the engine.
9. Fill the cooling system with engine coolant.
10. Install the throttle body air inlet duct.
11. Connect the battery ground (negative) cable.
Regards,
netvan
Mar 14, 2011 | 2002 Buick Rendezvous
Need a new flexihose for dryer, it is from the uk and i left the old one behind, it is not a condenser
Hello Mary, Just go down to your local appliance store or home depot / orchard supply / lowe's, etc., and ask a customer service representative for a flexible dryer hose. Before you go, take a measurement ( diagonally) with a tape measure to see how wide (in inches) the vent pipe in the back of the dryer is. This information will help the person assisting you. Also, get two clamps that will hold the flex onto the dryer pipe, and the outside vent pipe. If you have further questions, feel free to contact me. Good Luck, and I hope this works for you. - Jim
Mar 29, 2010 | Dryers
Brand new vented dryer causing condensation in
Hello, I would recheck the exhaust hose connections, as it sounds as if you've either got some holes in the vent hose/line or the connections are not fully around the dryer exhaust vent, etc.
You might also want to look at the dryer to see if the internal exhaust pipe came loose during transport and installation. It might be possible that the exhaust vent pipe inside the dryer is loose or off the fitting. An easy way to check this is to remove the exhaust pipe from the back of the dryer and (with the dryer unplugged from the electric outlet!) check by looking into the back vent on the dryer. You can also feel inside to see if it's loose, etc. Just be carefull as the metal pipe could have sharp edges, so wear some gloves to be safe.
As this is also a new dryer, you might also contact the place where you purchased it, as there might be an quality issue that they've received a service bulletin on and could provide you with further assistance.
I hope you find this Very Helpful and best regards!
Dec 14, 2009 | Tricity Bendix Dryers
My dryer comes on and spins, but it is not drying the clothes. What could be wrong?
Its most like to be the thermostat, temp sensor or the heating element is broken.
Sep 10, 2009 | Hotpoint Dryers
Exhaust Need to install side exhaust on maytag dryer
There will be an indented area about 4 inches in diameter if your able to put one in easily. Other wise you'll need either a hole saw 4" or cut a hole in the side of the dryer but before you do make sure your inside piping will reach the new area you want to come from.
Another suggestion would be make a base for your dryer to set on 6 to 8" high cut a hole in the side of it and in the top where you can run the dryer hose through then continue on outside with the hose-vent.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Maytag Dryers
Dryer lint throughout the house
Four Screws holding the exhaust pipe that the hose connects to on the lower back of the dryer. Remove those screws and pull the pipe out - It has a rubber gromet on the inside end that should fit onto the opening on the inside of the dryer. May need a flashlight to see inside while aligning it when putting it back in.
Feb 22, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer lint all over the house
Generally this would be caused by an open or tear in the flexable exhaust vent pipe to the outside. Look behind the dryer and determine if the flexible exhaust pipe is connected at both ends. With the dryer running you might feel a lot of warm/hot air in the area around the vent pipe if there is a tear in the foil. The fix is either to reconnect the pipe or replace it if the pipe has a tear in it. You should be aware that if the lint is exhausting into your home, it is likely the exhaust gas (carbon monoxide or other exhaust gases) are being injected into your home. If you are unable to repair this, you should call an appliance repair company and have a professional technician check out your unit.
Dec 12, 2008 | Whirlpool LER5636P Electric Dryer
I need to change the exhaust pipe vent for my tumble dryer. it has ripped. how do i go about fixing this or do i need a professional?
you can put an aluminum duct tape to the ripped portion just to stop hot air from venting from the damaged portion. or if the ripped portion is near the end where you put the flexible hose, then maybe you can move the flexible hose as far as it can reach as to cover the ripped portion of the vent pipe. then secure the flexible hose with a good hose clamp. i hope i was able to help
Jun 21, 2008 | Dryers
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Nov 20, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
