Question about Norcent Technologies PT4231 42 in. HD-Ready Plasma Television
Eske told me to ask you
Firstly, thank you for your reply. I don't have a good camera, so I'm sending you a pic I made. The thing is that the TV reaches a certain temp. and then these vertical lines show up. Like I said they are sporadic and only visible on darker pieces of picture (black or grey). Thank a lot for your trouble.
  • Norcent Tech... Master
  • 8,617 Answers
Thats usually related to the control board being defective when its across the entire screen, But check the ribbon connections on the control board
Posted on Jun 25, 2008
I have a philips plasma tv # 42pf7220a/37 has no pic. have replaced the power supply board with new one,still has red lite flashing 7 times. Have checked all capacitors and any thing that looked...
Good day!!!!
Blinks 7 times of your unit indicated bad power supply board but since you said that your power supply was now new then kindly try to reconnect all the connectors inside your tv before proceed to the advance process. May I ask if you know how to use a multimeter and soldering?...
Just add a comment for our next movement....I will do my best to help you...Thank you...
Jan 07, 2012 | Philips Televison & Video
My kid put a plug from the computer no power to it and it just went off it was pluged into the serivce port
It's probably just a fuse.
I don't have a physical layout of that TV inside though so if it's blown, I'd need pics.
Here's the possible good news though.
He may have simply tripped the power supplys' protection circuit.
Unplug the TV for 5 minutes and plug it back in, it may be fine!
It takes a while being unplugged to reset the power supply when that sort of thing happens.
If the TV still won't come on, you'll need to open it up and get some good shots on the power supply board and the board that the service port is on, and of the cable that connects the 2 of them together.
If the pictures are good enough, I can point out where the fuses are.
If the photos are necessary, post a comment or reply here and I'll give you an address to send the photos to.
Apr 11, 2011 | Vizio GV52LF 52 in. LCD TV
I was in contact with 'Eske' last night but had to leave in mid advice? Please advise?
well Eske has a profile page here and probably you could click on that ask me link, or alternatively, locate the chat or problem you had with him and add on. he would be notified by mail by the system.
Regards
Dec 16, 2010 | Video Game Consoles & Games
Did not get a disc with my dpix 5200 camera im unable to send pic
Prakticam, unhelpfully don't have anything for their cameras more than a couple of years old and don't seem to care if you mislay the disc you paid for.So be warned, don't buy Praktica. I have the 5200, you have firstly to put your usb in computer, switch on camera, switch camera to view pictures taken mode, and because it auto switches to take picture mode you then carefully attach camera end into camera whilst camera is still switched on! Then go to my computer and click on F: the pictures download. Then to save them click on first pic, hold shift key down and then click on last pic they should all highlight, right click and then hover 'send to' and send by left clicking to my documents. I remember that it took me 4 hours to work it out. Found this looking for manual to download, cannot change date now......
Apr 08, 2009 | Praktica Dpix 3000 Digital Camera
Horizontal lines in pictures
hi If u find that the lines are vertical that is often a result of taking pictures of very bright subjects. This is  called vertical streaking. If the lines are horizontal lines there is probably something wrong with your sensor and you should have the camera looked at by an authorized service technician , and they will send it out to have it looked at. hope this helps!
thank u rate me!!!
Feb 12, 2009 | Olympus FE-190 Digital Camera
Canon AE-1 won't rewind film without tearing it up.
misstigeress,
is the film being ripped along the sprocket holes? if so, the rewind button is not unlocking the drive sprocket. with film removed open the film door and push the rewind button in, the drive sprocket should turn freely. now charge the shutter with the advance lever. the rewind button should pop out and the drive sprocket should not turn freely.
if the sprocket did not turn freely with button pushed in, the camera needs repaired. there are no new parts for this model canon so any parts needed will be good used.
Nov 30, 2008 | Canon EOS-AE-1 35mm SLR Camera
PowerShot SD300
You can set Flash function by pressing flash button on camera. Button has 3 type of settings, flash Auto, Force, Off. If you need further help, please go to flash function in user manual and if you need further help, post back here.
Regards,
Aug 28, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Web &ppic msgs doesnt work
to connect to the internet & to send & receive pic messages you must activate the GPRS first from your network provider ...The best thing you can do is to contact the customer care of your network provider and ask for the activation of GPRS ...
they will tell you the procedure to activate it ....
they will tell the number to which the message to be sent to recieve the settings ....
so note that down and then follow the procedures told by them ...
you will receive the gprs settings(profile) also ... make sure of the charges with them there will be many plans & then get activated ...
after this you will able to connect to internet ....
any further doubts reply me
i am always here to assist you ..
thank you
bye...
Apr 15, 2008 | Nokia N70 Cellular Phone
How do you access the internet? The phone says you have to create an internet profile-how do you do this?
thank you
bye...
Apr 11, 2008 | Cell Phones
Norcent Technologies PT4231 42 in. HD-Ready Plasma Television Logo
62 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
