Question about Dell Latitude C400 Notebook
Installing memory in dell lattitude c400
Currently have 2 128mb and upgrading with 2 512mb. Replaced the one in the back, but don't know where the other module goes
  • ManuelLinar Jun 25, 2008
    Thanks, but I did remove the keyboard and the memory is not visible. I found another website that indicated that one of the memory modules was not "user accessible"; so I have given up on it.
  • ManuelLinar Sep 23, 2008
    It seems helpful, however I returned the other module and I am happy with one 128 and one 512. Thank you very much!
Remove the keyboard, remove the plate with screw numbered 1-6 and u will see the intern memory infront of u
Posted on Sep 22, 2008
    Genius:
  • 2,028 Answers
I have one of these myself, love it. The other memory chip is under the keyboard. Remove the plastic strip that has the power button on it, and you'll see the four screws holding the keyboard. Once you get the keyboard off you'll see the other memory chip.
Posted on Jun 25, 2008
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
Adding computer memory
The only thing you could do is put in a 256MB module in the slot that you have access to. Only one socket is user upgradable. The second socket is only upgradable by a Dell service center. They would have to install a second 256 module to get you to the 512MB max.
Jan 22, 2010 | Computers & Internet
How do you solve blue screen stop 7b in lattitude
blue screen errors are usually from a malfunction of the ram memory ...an fatal error of the system ...or a change of hardware without re-installation ...so ..if you know that your system its intact and has to work ...usually re-installation of the operating system ...I mean a brand new one ...not repair or upgrade...but one with formatting C partition ...will fix this problem ...also restore bios settings to the factory optimal defaults
Sep 05, 2009 | Computers & Internet
Can't upgrade memory
According to the user manual for your laptop, it can only support pc-100 memory. If your going to upgrade your memory just make sure you use pc-100 and also the max amount of memory is 256mb in each slot so you would be maxed out at 512MB.
You can verify the info from this link from Dell:
http://support.dell.com/support/edocs/systems/latc600/en/ug/features.htm
May 23, 2009 | Dell Computers & Internet
I would like to change my hard drive
If you are looking to save just a "small" bit of $ .. 2 - 1GB sticks should be cheaper .. but what is the current configuration . is it 1 - 1GB or 2 - 512MB or 4 - 256MB?
You have the option of IDE or SATA drive so either is an option .. You may want to get a drive copy utility and just "clone/ghost" your current to the new drive and then swap it to master and GO
Dec 26, 2008 | Dell Dimension 4600 PC Desktop
Cant get on internet via wireless or wired connection.
use the lan connection to get online, then once prob clears you should be all set, otherwise back up your data and a fresh install always does the trick
Nov 20, 2008 | Dell Latitude C400 Notebook
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Screen problem
fabson,
Here is the service manual for your laptop, it should help you fix your hinges.
http://support.dell.com/support/edocs/systems/latc600/sm_html/remove.htm#999384
Jan 22, 2008 | Dell Latitude C400 Notebook
Dell Lattitue C400 keyboard partially not responding
Hi!
If you have replaced the keyboard and still the issue is there, then you are right. The controller is shot. You need to replace the motherboard again for this type of issue.
Karlox
Dec 05, 2007 | Dell Latitude C400 Notebook
Ram
Here is a link that tells ya all... http://www.edgetechcorp.com/memory/upgrade.asp?cid=22951
Aug 04, 2007 | Dell Latitude C400 Notebook
Dell Latitude C400 Notebook Logo
95 people viewed this question
Alun Cox
