Question about Coby MP-C7085 MP3 Player
Coby Mp3 My Coby Mp3 has malfuntioned or so the comp says. I want to put songs on it. How can I fixed this problem?
  • Paupaul May 11, 2010
    What does your computer says exactly.
    Problem Solver:
  • 8 Answers
Try resetting the device by using a pin:
1. The rear bottom right corner there is a small hole, insert the pin, this will reset the device to its factory settings.
Try using Windows Media Player 11 to save audio files to your device it is a free download.
Posted on Jul 16, 2008
How do I put songs in playlist on my Coby MP620 MP3 player
The Coby is weird, but I found a way to create playlists. It might not be the "real" way, but it works :)
Before I plug the mp3 in my computer I create folders containing the songs I want for each play list. For example I'd create one folder labeled "work out" for songs I want to listen to while working out, and another folder labeled "sleep" for songs to listen to while sleeping, or you could label them based on artists or genre or etc. Then I would copy the songs I want in each playlist into their respective folders.
Next, I plug my coby into my computer, and open it's folder. (should be in computers, and have a icon with a C on it). I'd copy (or click and drag into the coby folder) my play list folders (the ones I labeled work out and sleep). Then eject and remove my mp3.
If you do this, when you turn on your mp3 you should select Music. Then select Broswer (on the bottom). Select the first row, which has the symbol "\" [underneath this is all your songs] and you'll see the names of your play list folders (they'll be below ROOT, MAC OS X Coby Me, and PHOTOS) . If you select your play list name you'll see and be able to play the songs under that playlist.
Feb 19, 2013 | Coby MP620 MP3 Player
How to get songs back in the coby mp3?
On the MP610 you could use either Windows Media Player 11 or Coby Media Manager for transfers of songs.
Next steps are important for adding files onto the player:
1. The player should be detected in the software for transfers, when connecting the USB cable.
2. Setup your library in the software (Add to library): There has to be a list of folders in the software manager, where your music is located on the computer.
3. Create a playlist in the software: make a list of songs, you want to transfer onto your player
4. Sync the playlist onto the player.
When needing more help, just add text in this reply.
May 11, 2010 | Coby MP-610 MP3 Player
How to i download songs from my music to player
open my music
and my computer
when in my comp... open colby file 4 ur player open music folder on player then drag ur music from :my music to you player
hope this helped
Apr 02, 2010 | Coby MP-610 MP3 Player
I transfered some songs onto the mp3 player. It froze up and won
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player should have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Apr 01, 2010 | Coby MP-610 MP3 Player
I can't put music or video into my mp-610 4G black
when you disconnect it try going to task bar and safely remove icon at the right and then disconnect the device.
Jan 21, 2010 | Coby MP-610 MP3 Player
I cant download music into it
Thry the solution below. If it does not work then you need to reformat. Also you might want to go to the coby website and download a updated version on the firmware and reflash your player. This will set it back to factory settings.
  1. Open Windows Media Player.
  2. Find and click the "Sync" tab. This is located at the very top of the program.
  3. Plug the Coby mp3 player into one of the USB ports found on your computer. Depending on the exact Coby mp3 player that you own, you can either plug the player directly into the USB port or by using the cord that came with the Coby mp3 player. The name of the Coby mp3 player will appear in the top right corner of Windows Media Player.
  4. Click "Library." This link will be on the left side of the program.
  5. Double-click the "Songs" option in the middle of the screen.
  6. Scroll through the list of music on your computer until you find the songs you want to put on the Coby mp3 player. Right-click on the title of the song and a drop box will appear. Select "Add to Sync List." You will then notice the song listed in the column located on the right side of the program.
  7. Repeat the previous step until you're finished putting songs on the Coby mp3 player.
  8. Click the "Start Sync" tab located beneath the list of songs you chose in Step 6. Those songs will then be added to your Coby mp3 player.
Sep 26, 2009 | Coby MP-705 Digital Media Player
How can I remove certain songs (not all) from my coby
Hello..
You have to connect it to comp to remove the songs from the player...
Cheers!!
Aug 03, 2009 | Coby MP-705 Digital Media Player
Cant upload songs to the mp3
When the firmware inside the Coby 610 becomes corrupt, it doesn't communicate with your computer properly, so your computer can't see it.
I hope that helps.
Unfreeze Coby 610
Jun 17, 2009 | Coby MP-610 MP3 Player
Problem with my Coby MPC7095 2 Gb MP3 player, Can you please help me
WHILE MY COBY MPC 7095 IS CONNECTED TO THE COMPUTER IT COMES ON BUT EVEN AFTER THE FOUR CHARGE ONCE DISCONNECTED FROM THE COMPUTER IT WILL NOT TURN ON PLEASE HELP.
Jan 17, 2008 | Coby MP-C7085 MP3 Player
MY Coby MP3 MPC-854 is receiving a malfuntion error.
I have put music on my mp player. How do I get it to work? Help
Dec 10, 2007 | Coby MPC-848 MP3 Player
Coby MP-C7085 MP3 Player Logo
37 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
