Add to format computer,got every working again except internet.I have misplaced software for motherboard (ASUS A7N8X Deluxe)Is it possible to replace software disc. Hope this possible. Thank You
  • 3 Answers
Try windows updates and see what you get but most internet providers come with the software needed for the internet to work
Posted on Jun 25, 2008
MOTHERBOARD DOES NOT
It is embedded on motherboard. Download driver.Unzip. Run setup in marvell_v627\Marvell\Win2K_XP after extraction.
Asus A7N8X-E Deluxe Marvell LAN Driver 6.27
Oct 03, 2012 | ASUS A7N8X-E Deluxe Motherboard
Ethernet driver for a7n8x-e
You can download your driver here:
Hope this helps!!
Please rate!!!
Jan 02, 2010 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
ASUS A7N8X-E Deluxe Motherboard supports 1TB SATA2 HDD?
1) Grab a blank floppy, and a computer running Windows with a floppy drive.
2) Download C18E1013.zip (A7N8X-E Deluxe Latest BIOS, from Asus), AWDFLASH (Also from Asus), the latest Silicon Image SATARAID BIOS (from Silicon Image), and CBROM 2.15 (Alternative CBROM 2.15 download link)
3) Extract all the contents of everything into an easily accessible folder, preferably something like C:\bios
4) Make sure you have no other folders in this new folder. Everything must be within C:\bios, so for example there shouldn't be anything in C:\bios\BIO-003112\
5) Open a command prompt (Start -> Run, type "cmd" and hit enter, without the quotes)
6) Navigate to the folder you just created using the command "cd" (For example, if you used the folder I suggested above, you would type "cd C:\bios", without the quotes, and hit enter)
7) Now type "cbrom215 c18e1013.bin /pci 4284.bin" without quotes, and hit enter. This will take the latest BIOS for your motherboard, and merge the new SATARAID BIOS into it.
8) To make sure everything went correctly, type "cbrom215 c18e1013.bin /D". This will show a list of the modules in the BIOS. At the bottom should be a line with PCI(A), and should have "4284.bin" at the right end of that line.
9) Now put the blank floppy into the computer with the floppy drive.
10) Open My Computer, right click on the floppy drive (probably A:), and select "Format"
11) The formatting window should pop up. Check the box labeled "Create an MS-DOS startup disc" (which should disable all the other options), and click Start.
12) Click OK and close the format utility when the process completes.
13) Copy the modified BIOS file c18e1013.bin and the file AWDFLASH.EXE to the floppy disc (simply a drag and drop).
14) Close everything on the computer with the A7N8X-E Deluxe motherboard and reboot it. Make sure the computer is set to boot to the floppy drive, and that you have put the floppy in the drive.
15) Type the command "awdflash c18e1013.bin /py /sn" once you get to the "A:" prompt.
16) Press enter to confirm that you wish to overwrite the current BIOS.
17) Wait.
18) Once it says it is complete, remove the floppy, press F1 (as instructed), then reboot the machine (which should happen automatically once you press F1). Now the computer should detect the 1TB drive upon booting.
Jul 02, 2009 | ASUS Computers & Internet
Can i replace supreme fx with fxII on my asus a7n8x-e deluxe
mother board as class as form factor this is a standard connector and mounting style if the two board you are trying to replace are the samr form factor then yes it should fit make sure the all you parts like the cpu and the video are compatable. if you using a agp video card then make sure the board has an agp slot and it the correct speed bou other then those type of checks it should work if thing match up the form factor
Jun 10, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I need to know where the power and hdd led jumpers go asus a7n8x
Don't you have a manuall for your motherboard ?
Check it here:
http://support.asus.com.tw/download/download.aspx?modelname=A7N8X-E Deluxe&SLanguage=en-us
Be sure for polarity of the connectors (not 'jumpers' as you say)
Regards.
Mar 28, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I have an asus a7n8x-la mother board. It ran fine except the cpu cooling fan would speed up and the cpu heat sinc was very warm as compared to others. Finally it would not boot or go to post with the beep....
First of all set the BIOS default.
i think somebody change your Bios settings like-- over clocking or speeding fan etc etc.
add comment for further assistance.
Good Luck!
neo
Feb 27, 2009 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Which GB ram seaport
\ x 184-Pin DIMM Sockets ddrsdram x 184-Pin DIMM Memory Type
DDR Maximum Memory 3 GB
Your board support maximum 3 gb ram with above mentioned details
Regards
Balisonu79
Feb 14, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
What wireless card to connect to A7N8X-E deluxe ?
From Asus website:
"The Wi-Fi slot is specifically designed for the ASUS Wireless LAN add-on card"
Nov 05, 2007 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
