Question about GE Microwave Ovens
New SS microwave Model#JE31142SJ04, Ser# UM900970U runs very loudly and we don't know if our control panel should light or not. It's very hard to see the numbers. Can you enlighten us?
  • GE Master
  • 9,086 Answers
If you don't have your owner's manual you can download it here.
I would assume the control panel should be visible.
Is the voltage correct at your outlet? Any other trouble with any other electrical items or outlets in the home?
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
The fans on this microwave will automatically turn on when I have more than one burner on the gas range going. The fan is horrendously loud and will not allow me to shut off for 2-3 minutes regardless if I...
That's typically normal operation. The microwave has a thermostat which turns on the hood vent exhaust fan at a certain temperature to protect the controller.
Your owner's manual will cover vent fan operation.
If for some reason you don't have yours, you can download Whirlpool owner's manuals and installation instructions here.
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If - above and beyond this - the fan has a problem, that could make it excessively loud. Some are just loud though, it's hard to judge without actually hearing it.
You can contact Whirlpool customer service with your model number via that link above and ask them about the loudness. They may be able to tell by listening over the phone if it's abnormally loud.
Apr 28, 2011 | Whirlpool MH7130XE Microwave Oven
Display panel has lost most of its dots. can't read it
debe ser revisada por un tecnico por que parese ser la targeta de control da?ado por incectos o por cucarachas
Oct 05, 2010 | Sharp R-1750 Microwave Oven
Make loud crackling noise after running for a few seconds and does not heat
Chances are it is a blown high voltage diode. Not too hard a task for the DIYer.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here is a link you or someone you know can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 27, 2010 | GE JVM1630 Microwave Oven
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
Apr 30, 2008 | Whirlpool GH7145XF Microwave Oven
Microwave Fan Running for 24 hours
Sounds like cycling the power line did it.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
