Question about Dell Latitude D600 Notebook
Power Problem my dell d600 connot power on, even when plug to ac power connot indicate any light to show that it charges
  • olisa01 Jul 01, 2008
    which one is the pm chip on the board, can you show me the location on the motherboard. thank so much
  • dan gillum Jul 03, 2008
    hello: i have a problem turning on the laptop with the battery out and a/c adapter plugged in, it comes on for a second and turns off. with battery in it charges and comes on,but it shows on power meter charge and discharge constily it goes dimmer to brighter when doing so. can you help me please?
I have the same problem try tapping it on the bottom while hitting the power switch
Posted on Jul 03, 2008
Try a new battery oa adapter found here laptop battery store
Posted on Jul 02, 2008
  • 2,028 Answers
This could ba caused by several things. First, a bad power supply. Second, a bad battery, try starting it without the battery. Third, a bad memory chip. And fourth, the power management chip on the motherboard. If it's not the battery, power supply, or memory chip, then it's the pm chip and the motherboard will have to be replaced.
Posted on Jun 25, 2008
My dell latitude d600 won't recognize the AC power adapter and doesn't show that the battery (which is new) is charging. I had to leave it plugged in for about a week when I put in the new battery before...
There was a class action suite against Dell for this problem with this model laptop due to overheating and destroying the power supply. Browse the web for more information. I have one and it is a parts machine now.
Jul 29, 2009 | Dell Latitude D600 Notebook
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Battery will not charge on a dell d610 when plugged into outlet
I have seen this with faulty batteries.
Try changing the battery.
Also, check in the BIOS that the adapter you are using is recognised and shows a state of charging with the battery in.
Apr 01, 2009 | Dell (F2273) Motherboard
Notebook not charging
if the AC adapter port itself on the computer is loose even if you tried different AC adapters, the motherboard of your system will need to be replaced. If the warranty of your computer is still active, you can request a replacement motherboard from Dell. Otheriwse, if the warranty is no longer valid, you either need to purchase a replacement board, or try to use electric tape around the end of the AC adapter to fill it the gap when attached to the port on the computer.
Mar 16, 2009 | Dell Latitude D600 Notebook
This started last night, my battery indicator
The red or amber flashing lights indicate a bad battery. The Dell battery warranty is only for one year and the D600 has been out for a number of years. You should replace the battery. You can use the laptop as it is as long as it is connected to AC power.
There are several places to buy replacement batteries. One is If you do a search on the web you should be able to find other sources.
Good luck and I hope this helps, even if it isn't good news.
Feb 28, 2009 | Dell Latitude D600 Notebook
My dell d600 wont come on even when i put the charger on
If the system shows no power indication when trying to power on or if you get only a momentary flash of the Power LED, then it goes off, the first point to check is the AC Adapter. If possible, try a known good adapter from another D-Series Dell. Check the LED on the AC adapter to see if it is ON before connecting it to the system. If it is and it goes out when you plug it to the system.
If the LED goes out and no other adapter is available, then I'd start with a new AC Adapter. (If you have no known good adapter available, you might try taking it to best buy and see if they can connect the system to a known good there to see if it powers on).
If replacing the AC Adapter does not resolve your issue, the motherboard is the next component to replace.
Feb 20, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 blinking battery light
I would say its defective. Bring it back to where you bought it and show them. Bring your laptop charger also so you can show them it in action. Hope this helped.
Jan 04, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Aug 15, 2008 | Dell Latitude D600 Notebook
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
Nov 02, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
99 people viewed this question
Alun Cox
