I have a duel deck VCR that will not turn on. I replaced the fuse but that did not cure the problem. Is there somewhere that I can send the VCR for repairs? Robert Lowery rllnnl@vvm.com
  • 144 Answers
Dear Sir,
Unless you are a repair technician, please do not try to open / service the equipment because there is a risk getting fatal electric shocks.
Do not touch any part inside when the VCR power is plugged on.
If you have VOM, try this. Check Power Cable & AC outlet are ok by VOM on AC range.
If your VCR has provision for DC batteries, them check at back of VCR for DC/AC switch. Keep it on AC & check.
Check if your VCR is in warranty or not/ take it to the service center.
Hope this helps.. Best Luck..
Posted on Jun 25, 2008
  • Anand Salunke
    Anand Salunke Jun 25, 2008
    Also Check if you have 230/100 V switch at the back of your VCR on right side i.e 230 V side or 110 V side. Depends on normal AC voltage in your country.
  • 2,071 Answers
Maybe the switch to turn on,, is defected already thats why,it will not turn on ,this the most common problem also, this only tacking switch, find a technician to do repair to and to change spare parts , in order,to avoid high voltage shock...
    Genius:
  • 1,142 Answers
Which location do you live ???
  • Maanita Chadha
    Maanita Chadha Jun 25, 2008
    Need to contact a local technician who can take care of the powersupply unit which must have gone bad.
    Guru:
  • 1,894 Answers
Best place is to send back to the company service center
can u mention ur make of the VCR ?
Before I cleaned the head, no pic.. after cleaning the head, no pic.. what do I do?
If you can hear the sound then cleaning the head sometimes works. Unfortunately no amount of cleaning will cure a faulty VCR head
By the way you posted this in the cassette and Reel to Reel tape section not the VCR section so it took me longer to see this.
Dec 07, 2015 | Audio Players & Recorders
VCR will not turn on
any led indicators that the unit got a power..?
Jun 25, 2008 | Televison & Video
GoVedio duel deck VCR Model # GV3060x will not turn on. Fuse is good but change it out anyway but it did not cure my problem.
the problem can be due to some other component on the power board. have u replaced the power board fully?
Replaced blades duel deck high spot in cut grass on right hand side. thanks.Mower is rover lawn king.
Try leveling your deck beacuse it sounds like the right hand side of the deck is too high causing the high spots. move the mower to a flat surface, drop the deck to its lowest point and measure the deck height with a tape measure.
Nov 27, 2010 | Garden
My tape is stuck inside and i want to eject
Locate any screws that hold the top in place. carefully slide the top off. find the loading motor. it should have a worm gear on it. turn the gear and after a while the tape should come out. is this only in one vcr in the duel deck? please reply if you can fix it. if that did not work, just let me know. good luck!
Jul 09, 2010 | Rio Go Video DDV9050 Dual Deck VCR
10 A Fuse blows each time I shut off engine. Short somewhere? Suggestions? Craftsman 19 hp Briggs & Stratton 42 inch deck. Probably 10 years old. Thanks! Mike
Yes, probably a short, and I think you should look at the ignition switch as the first suspect. It has two switches inside - one to send battery power to the various components, and a separate one to ground out the magneto when the mower is turned off. Could be a short between the two parts of the switch. Test it if you have the tools, otherwise try replacing it. Good luck! If this is helpful, please take a moment to rate my solutions, thanks!
Jun 10, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Unevan cut duel blades adjust deck
If the mower has been cutting fine in the past, and you do not see anything loose on the deck between the deck and the chassis. I would check the air pressure in each tire.
HTH
Good Day.
Oct 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Worn out belts
Thanks anyway but I was able to find the drive belts I needed.
Jan 09, 2009 | Rio Go Video GV6060 Dual Deck VCR
Goldstar GVR-E455 VCR can not be turned on
Most VCR have a glass fuse like these below.
In this picture the fuse is located at the bottom left coner of the board.
Az.
Sep 15, 2008 | Goldstar GVR-E455 VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
