Washer leaking Kenmore toplaoder washer. leaks during wash and spin cycle (not alot) can it be repaired
  • 95 Answers
Check your drain for cracks or holes, could also be a loose clamp, or simply overloading
Posted on Jun 25, 2008
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washer leaking water out bottom in rinse or spin cycle.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jan 24, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Leaking water during spin cycle
Likely the tub seal is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore Washing Machines
Water leaks during drain cycle and the machine
Hi
If the water leaks during drain and spin only: A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 17, 2009 | Washing Machines
Water runs during spin cycle
I would suspect that you timer is shot, only during spin? During the day when water use is high does it leak then?
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
