Question about GPX HM3817DT Shelf System
Disply light is too bright!
Hi! Can I turn off or turn down the display light? It's very, very bright and I can't sleep with it on (I have the radio on while sleeping). Thank you.
I have the same problem and my current solution is to cover the unit. I am looking to see if there is any way to turn the light off as well
Posted on Aug 23, 2008
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
Unable to adjust brightness on my sony xeperia L phone please help
hi there,if led lights blinking maybe your phone just gone to "sleep of death"... just remove the battery and wait for a while,..if problem still persist after boot,try sony update service on your pc(resets all your data)it works for me,....goodluck!
Jul 19, 2014 | Sony Ericsson Sony MT25i Xperia neo L...
Tcl tv screen
hi go into the menu on your tv scroll to picture setting turn the brightness down also look for bl which means back light set it to about 10 hope it helps
Jan 25, 2014 | Televison & Video
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
Radio display is not bright
Press and hold alarm time for about a second, then press your tune/playlist button until your bright hi or bright lo choices display, once you chose which lighting you want, do not press anything else. It will set to your last selection.
Oct 31, 2010 | Bose Wave Radio
LED Dimmer on Emerson CKD 9901
On Those Clocks No You Can't
I Normally put a shirt over the led screen light that way i can sleep hope ive been helpful to you
Jul 17, 2008 | Emerson CKD9901 Clock Radio
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
GPX HM3817DT Shelf System Logo
182 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
