NorStar M7324 Telephone Logo
Anonymous Posted on Nov 30, 2010
I forgot my system coordinator mailbox # and password!? I have other other extentions set up with employees that are not able to access thier voicemail messages and need to update their greetings how can I help them as well?! ps. I already tried "To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000. " but it didn't work!!!
  • 1 more comment
  • george  peters
    george peters Nov 30, 2010
    What is the length of you intercom numbers? Usually there either 2 or 3 digit intercom numbers.
  • Anonymous Nov 30, 2010
    3 digit intercom I think I found the password for it! Is it 1020000 and if so can i just keep it that way?
  • Anonymous Dec 17, 2010
    I have another problem with my NorStar M7324 Telephone, only the front desk rings when we get incoming calls, I need it to enable it for all the phones too!?
george peters
Level 3:
President:
  • NorStar Master 860 Answers
  • Posted on Dec 01, 2010
george  peters
NorStar Master
Level 3:
President:
Answers
860
Questions
0
Helped
609260
Points
3471
You can keep it at the default password. It will allow you to do everything except remote recording of the main greeting with a default PW.
Voice mail locked after various attempts at putting wrong password in. How do I rectify?
Your mailbox is assigned a maximum number of incorrect password attempts.
Norstar Voice Mail records the number of incorrect attempts from the last time your mailbox was successfully accessed. Once the number has been passed you are"locked-out" Your mailbox cannot be opened again until the System Coordinator resets the password
3helpful
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Need to change password on voicemail extension on
If it's a Panasonic brand voice mail, you administer the system from the System Owner's mailbox (999). With that, you can use option 4 or 5 and reset the mailbox password to any and all mailboxes (except 999 :-)
Carl
7helpful
How do I reprogram the main message on my Lucent Partner 18D and how do I access a line where my employee quit, so I can get her messages?
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,3 for greetings, 1 for auto attendant number, 1 for day greeting 2 for night( if your using a night key at the receptionist station then it usus the night greeting) # to go past selector codes, 1 to start recording 3 to accept greeting hang up when done.
As far as the employees voicemail messages, while in the voicemail administration you can reset her password in the "administer mailboxes" prompt which is either 2 or 4 depending on the voicemail type you have. that will reset her password back to 1234.
4helpful
I have the same problem: mailbox locked
How to Change a Mailbox Password (Administrator Only) 1. To access the voice mail system press "Feature".
2. Press "983".
3. When you see "Log:" enter "120000" for 2 digit extension numbers, enter "1020000" for 3 digit extension numbers.
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number (same as extension number) you wish to reset.
8. Press "Reset" softkey.
9. Press "Rls" to exit (orange button to the right of the number buttons).
The Default password is "0000".
1helpful
Need to access voicemail with no password-panasonic KX-T230 phone
Find the password to mailbox 999 or call a Panasonic dealer.
Carl
Need to set up user voicemail box (new employee)
Go back to your vendor and get the password for mailbox 999 and the instructions to log into it.
The mailbox exists or it wouldn't ask for a password (they're assigned by default), so you need to go to mailbox 999 and chose option 6 1 3 which is mailbox administration reset password. That will clear the password and you can log into the voice mail automatically from the extension by dialing the voice mail access code.
Post back if you have any problems.
Carl
How to set up password for voicemail/how to set up new mailbox
By default, a Panasonic TVA voice mail system can have a password set. It could be 3 plus the extension number, but it doesn't matter. You can clear it by logging into mailbox 999 and going to options 6 1 3 which will be the mailbox password menu. Select the lady's extension and follow the instructions to confirm password deletion.
Now she can call voice mail from her extension and set a new password.
This also works for a TVS system.
Carl
3answers
How do I change the voice mail recorded message? How do I get a manual for this existing system?
IF you know the password for the mailbox then log into the voicemail by dialing the Stratagy access code, after Stratagy answers dial * , then your user ID mailbox number plus #, then your security code plus #. The User Main Menu plays, press 2 to change your greeting, the Select Greeting Menu plays, press the greeting number, the Record Menu plays, press 2 to record your greeting, Record greeting, as soon as you finish press #, the Record Greeting Menu plays, press 1 to review or 2 to re-record. Press 9 to save and return to the Select Greeting Menu and 9 again to return to the User Main Menu, hang up at this point.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
