Question about Microsoft HP Pavilion DV6276US Notebook PC
Battery Charge I have an HP Pavilion Entertainment PC dv2000 and when it is plugged in it states that the battery is not charging - the battery life has slowly been dwindling and is now next to nothing. How do I get the battery to charge when plugged in.
    Genius:
  • 2,028 Answers
The battery needs replaced. After all, it is a battery and batteries eventually wear out.
Posted on Jun 25, 2008
How to extend the battery life of your laptop HP/Compaq pavilion dm4
Tips to increase battry life:
1. Never charge when battery already full.
2. Keep low Brightness.
3. Keep volume medium.
4. Always use headset to hear songs or see films.
5. High graphics games never play on laptops it reduses your lapy's battery life.
6. Never use laptop up to 0% battery power.
7. Close background processes using task manager(these processes not essential but consume battary.
Jun 21, 2013 | HP Pavilion dv6000z Notebook
I have HP Pavilion Dv4 1030ee laptop From Last 1 week i have seen that 'plug in but not charging'.my laptop battery is not charging bt working fine on connecting to ac
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 19, 2013 | Computers & Internet
How to fix hp dv2000 power problem
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 12, 2013 | HP Pavilion dv2000t Notebook
HP Pavilion Entertainment PC doesn't charge
problem with motherboard replace motherboard
Oct 08, 2012 | HP Pavilion DV9500Z Notebook PC
My HP pavilion ze4949 will not charge the battery. I got this laptop 2nd hand, and the "charging" light that the manual states should be lit while the AC adapter is plugged in has never lit;...
Take the battery out and see if the A/C charger will run the PC.
If so the portion of the PC Motherboard that charges the battery has failed.
The Motherboard is the heart of the PC and quite difficult to replace at home.
Go to a PC repair and see if it is worth fixing. BIG Labor cast.
Sorry!
Aug 13, 2011 | HP Pavilion dv6000z Notebook
My advent verona turns off when the charger is unplugged it is 14 months old and has been minimally used ?
If a recharageable battery has been left in a low state of charge for a long time, the battery will be damaged and the battery life shorten considerably.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 19, 2011 | HP Pavilion dv9000z Notebook
How long is the battery on a HP Pavilion dv9000 supposed to last?
Laptop batteries will usually last from 1.5 to 5 hours, depending upon the demand, the battery and the use. Sound burns up a lot of juice as does the DVD player so if you're watching movies or playing games an hour is about right. You can purchase a better HP PAVILION DV9000 Battery with 12 cell , it will work longger.
detail: http://www.battery-center.net/hp-pavilion-dv9000-battery.html
Dec 04, 2009 | HP Computers & Internet
Battery life is very short
Not really. What happened is you shorted the life of the battery by always having it plugged in and in a charging state. The battery has a memory and since it's always been plugged in, it will never charge fully. There are products out there that will drain your battery down and reset the memory issue. But it would be cheaper to get another battery. If you are going to keep it plugged in the majority of the time, charge up the battery and remove it.
Jul 25, 2008 | HP Pavilion dv1000 Notebook
Lap top battery dead?
Probably the extreme heat and dryness out there drained it out, and or not being able to recharge it to full capacity. Did you charge it the recommended hours to charge when first used as stated in the manual the battery?. If you have access to a freezer put the battery in a ziploc bag seal and leave in the freezer overnight then take out and charge your battery overnight it might come back to life and hold it's charge once again.
May 04, 2008 | HP Pavilion dv6000z Notebook
Microsoft HP Pavilion DV6276US Notebook PC Logo
113 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
